mattvr6 133 Posted June 11, 2012 Report Share Posted June 11, 2012 Thinking of gettin a 4bar fuel reg?! R they worth it? Link to post Share on other sites
UnitedMotorsport 55 Posted June 11, 2012 Report Share Posted June 11, 2012 What do you aim to achieve by doing this? Link to post Share on other sites
VIW28 29 Posted June 11, 2012 Report Share Posted June 11, 2012 If your engine is properly tuned all you will achieve is overfuelling which is a bit pointless really Link to post Share on other sites
lee123d 0 Posted June 11, 2012 Report Share Posted June 11, 2012 What about if it isnt tuned Link to post Share on other sites
UnitedMotorsport 55 Posted June 11, 2012 Report Share Posted June 11, 2012 If it tuned or not doesn't matter: A VR6 has injectors more than big enough for its NA output,. Some people even run low boost on them.The reason I asked what your goal is this: If your going forced induction and need more fuel, then fine, as who ever is tuning it can build this into your tune. That being said, you will be better off with larger injectors.If you think that you need more fuel and your engine is NA, your wrong AND the ECU will work around this with no power gain. It works like this. In normal closed loop lambda regulation the ECU calculates a lambda correction factor, If you put a 4 bar FPR into a system that is 3 bar, the ECU will calculate roughly -10% trims. This trim value is then applied to the entire rev range. The ONLY thing you get from doing this is big negative fuel trims. Fuelling across the rev range after adaption will be IDENTICAL for 3 bar and 4 bar FPR'sIn short. If your are NA, don't waste your time or money. Link to post Share on other sites
FishWick 21 Posted June 12, 2012 Report Share Posted June 12, 2012 Low boost on stock injectors? Really?! I would never chance that. Certainly not before they've been flow checked and cleaned etc as they're nearly 20 years old now some of the VR6 injectors.How come VW went up to 4 bar on the Corrado? To get the power at the top end or to improve low duty atomisation because of the slower gas speeds from the less restrictive intake? Link to post Share on other sites
VIW28 29 Posted June 12, 2012 Report Share Posted June 12, 2012 All OBD1 VR engines ran 4 bar Kev which is why all Corrados have them. I guess it was maybe to do with the factory software or something but im sure Matt would be able to confirm that.Also, anywhere to 6psi or so seems to be fine on standard injectors. Stage 1 with a Vortech charger helps produce 250hp or so, that software uses factory injectors. Link to post Share on other sites
craggsy 91 Posted June 12, 2012 Report Share Posted June 12, 2012 I had standard injectors in with my rotrex install on a 6psi pulley Link to post Share on other sites
UnitedMotorsport 55 Posted June 12, 2012 Report Share Posted June 12, 2012 Low boost on stock injectors? Really?! I would never chance that. Certainly not before they've been flow checked and cleaned etc as they're nearly 20 years old now some of the VR6 injectors.Me eitherHow come VW went up to 4 bar on the Corrado? To get the power at the top end or to improve low duty atomisation because of the slower gas speeds from the less restrictive intake?They didn't. When the VR6 was 1st produced (OBD1) they were 4 bar and then when going to OBD2, they went down to 3 bar. Remember all Corrado VR6's were OBD1 from the factory.I can only think they did this to stay in line with the design/test characteristics of the injector they used, and also reducing stress on the fuel pump. Link to post Share on other sites
lee123d 0 Posted June 12, 2012 Report Share Posted June 12, 2012 Mines obd1 and has a 3 bar not a 4 bar but i bought a 4 bar and must admit it did make it run better Link to post Share on other sites
mattvr6 133 Posted June 12, 2012 Author Report Share Posted June 12, 2012 That answers that then,got a turbo kit ready 2 bolt on in the winter Link to post Share on other sites
lee123d 0 Posted June 12, 2012 Report Share Posted June 12, 2012 So u going for one or not mate Link to post Share on other sites
mattvr6 133 Posted June 12, 2012 Author Report Share Posted June 12, 2012 I'll get one anyway only 40notes got one then 4 when I turbo it mate Link to post Share on other sites
lee123d 0 Posted June 13, 2012 Report Share Posted June 13, 2012 Ive got one for £20 genuine bosch one Link to post Share on other sites
mattvr6 133 Posted June 13, 2012 Author Report Share Posted June 13, 2012 Wheres that from mate? Link to post Share on other sites
lee123d 0 Posted June 13, 2012 Report Share Posted June 13, 2012 Im in southampton but can post if need be Link to post Share on other sites
FishWick 21 Posted June 13, 2012 Report Share Posted June 13, 2012 I can only think they did this to stay in line with the design/test characteristics of the injector they used' date=' and also reducing stress on the fuel pump.[/quote']But aren't there 3 and 4 bar rated pumps though? The OBD2 Golf's is definitely a different unit to the Corrado's.I was just curious really. It just seems odd to use identical injectors on ODB1 and OBD2, but run 4 bar on one and 3 bar on the other. OEs do like to chop and change though!! Link to post Share on other sites
jims13 6 Posted June 19, 2012 Report Share Posted June 19, 2012 i was under the belief the pumps are the same flow wise, bar any physical differences. mattvr6 - grab a set of 440's they will see you fine unless you want mega power, alternatively 630's Link to post Share on other sites
