mossbomb 0 Posted May 31, 2012 Report Share Posted May 31, 2012 right had new head gasket water pump radiator thermostat new coolant pipes and still boiling over im thinking cracked block ive lost all patience Link to post Share on other sites
cabrioman 6 Posted May 31, 2012 Report Share Posted May 31, 2012 what colour is the pressure cap ???? if its a black one you need to get a blue one .... did you have the head pressure tested while it was off ??? Link to post Share on other sites
VeeRsix 0 Posted June 1, 2012 Report Share Posted June 1, 2012 Thats a bummer m8 id remove the head again and as TonyVrt suggest have CT if you havent done already or DIY with a polish and food colouring.Stephen Link to post Share on other sites
VeeRsix 0 Posted June 1, 2012 Report Share Posted June 1, 2012 Thats a bummer m8 id remove the head again and as TonyVrt suggest have CT if you havent done already or DIY with a polish and food colouring.Also do a wet n dry compression test prior to disaembly n post the resultsStephen Link to post Share on other sites
mossbomb 0 Posted June 2, 2012 Author Report Share Posted June 2, 2012 ye it was pressure tested passed and was refaced washed cleaned im just losing patience with it now and today its started misfiring bad and noticed alot of oil on my back bumper window hmmm Link to post Share on other sites
cabrioman 6 Posted June 2, 2012 Report Share Posted June 2, 2012 could be rings or steam seals is it smoking ???? where the steam seal replaced when the head was done ??? Link to post Share on other sites
yakuza racer 16 Posted June 5, 2012 Report Share Posted June 5, 2012 the answer:there is an O-RING in the expansion tank cap, it will be worn, i had the EXACT same issue and after many days of fitting and refitting things i found it out.check it out and update! Link to post Share on other sites
