sharky_70 0 Posted March 1, 2012 Report Share Posted March 1, 2012 ive been doing a fair bit of research into fitting a Rotrex as ive found a place that does a basic C30-94 kit for a good price. i'd only need to sort the VR specific parts like the mounting bracket and decide what pulley and injectors etc i wanna runnow ive looked at some build threads (seem quite old and thin on the ground) and wonder if some of the early fitting issues were still apparent r if things had changed.my main concern is that a few people have had to grind a bit of the head to allow for clearance. this seems a bit ott for a 'bolt-on' kit. is this still the case? seems its only on some heads not others.also does anyone know where else can supply a bracket? all i can find is ccr-racing Link to post Share on other sites
MJ Vr6 79 Posted March 2, 2012 Report Share Posted March 2, 2012 My mate has just fitted a brand new Rotrex in.I did quierie this with him yesterday, as we shaved a bit on my head for my Vortech.He said that he modified the bracket for the Rotrex..Did not touch the head at all.I can try and get a Pic tonight if I can as its n the bodyshop now. Link to post Share on other sites
MJ Vr6 79 Posted March 2, 2012 Report Share Posted March 2, 2012 Found a pic..Dunno if its any help as its really not that close. Link to post Share on other sites
sharky_70 0 Posted March 2, 2012 Author Report Share Posted March 2, 2012 if you could find out how he modified the bracket that would be a big help. rather do that than mess about with the head.what spec is he running? do you know where he sourced the bracket or did he buy a complete kit? Link to post Share on other sites
craggsy 91 Posted March 2, 2012 Report Share Posted March 2, 2012 It all depends on the head. My '97 head was fine with my rotrex, as in was bolt on.Tho when I swapped heads to a flowed head which came from an earlier car, we had to take a corner off the head to clear a pulley.Parts will only be available from ccr Link to post Share on other sites
MJ Vr6 79 Posted March 2, 2012 Report Share Posted March 2, 2012 if you could find out how he modified the bracket that would be a big help. rather do that than mess about with the head.what spec is he running? do you know where he sourced the bracket or did he buy a complete kit?Will ask him today for you.He is runnin 10psi+ and the Rotrex was all brand new mate, so all came as a package. Link to post Share on other sites
sharky_70 0 Posted March 5, 2012 Author Report Share Posted March 5, 2012 It all depends on the head. My '97 head was fine with my rotrex' date=' as in was bolt on.Tho when I swapped heads to a flowed head which came from an earlier car, we had to take a corner off the head to clear a pulley.Parts will only be available from ccr[/quote']sounds promising, mines a highline so wouldve thought its ok then Link to post Share on other sites
poll250 0 Posted March 7, 2012 Report Share Posted March 7, 2012 AFAIK you shouldn't need to cut a section out of the head for OBD2 cars, only OBD1. I had to cut a bit off mine when I trial fitted my old Rotrex kit. Link to post Share on other sites
sharky_70 0 Posted March 7, 2012 Author Report Share Posted March 7, 2012 i had suspected that as most of the builds i'd read were for corradosstill be interesting to hear what the bracket mod is as its something i remember seeing before too Link to post Share on other sites
sharky_70 0 Posted March 20, 2012 Author Report Share Posted March 20, 2012 another Q...is it best to fit the maf pre or post charger? ive seen both done but couldnt find anything definative. if its pre then is it likely i'll have to extend the maf wiring? Link to post Share on other sites
craggsy 91 Posted March 20, 2012 Report Share Posted March 20, 2012 MAF before the charger on Rotrex Link to post Share on other sites
