baz8328 0 Posted February 16, 2012 Report Share Posted February 16, 2012 Please HELP i am losing my love for my VR6 I have had my manifold powder coated .Fresh service and gasketsNow its all back together it will not fire up !!I have got good spark and fuel getting to the fuel rail / fuel pressure regulator.Checked coil pack etc and all working BUT STILL NOTHING !!Only other job I have done is relocate the battery to the boot but will check tonight by putting battery back to original position !!ANY ADVICE WOULD BE APPRECIATED !! Text 07921519734 Link to post Share on other sites
Biggazvr6 0 Posted February 16, 2012 Report Share Posted February 16, 2012 is the car attempting to fire or not? Link to post Share on other sites
ashmk3 0 Posted February 16, 2012 Report Share Posted February 16, 2012 Plugged all vacuum lines back up? Link to post Share on other sites
baz8328 0 Posted February 16, 2012 Author Report Share Posted February 16, 2012 It's turning over but not starting ! Got spark and fuel !Could I have flooded it ? Link to post Share on other sites
baz8328 0 Posted February 16, 2012 Author Report Share Posted February 16, 2012 It's turning over like it wants to start ! But won't !Could I have flooded it ? Link to post Share on other sites
cabrioman 6 Posted February 16, 2012 Report Share Posted February 16, 2012 take the plugs out and see if they are wet ..... if they are let them dry and let some air into the engine to try and dry it out a bit and try again .... just have a double check make sure everything is plugged in and fitted correctly .... Link to post Share on other sites
michael5556 247 Posted February 16, 2012 Report Share Posted February 16, 2012 If you have moved the battery, have you connected all the earths back up properly? I did this and had to earth the starter to the chassis myself Link to post Share on other sites
baz8328 0 Posted February 16, 2012 Author Report Share Posted February 16, 2012 It's sparking ok so would the earth to starter stop it from starting Link to post Share on other sites
cabrioman 6 Posted February 16, 2012 Report Share Posted February 16, 2012 have you got the leads in the correct firing order ???? Link to post Share on other sites
baz8328 0 Posted February 16, 2012 Author Report Share Posted February 16, 2012 Yes ! Link to post Share on other sites
michael5556 247 Posted February 16, 2012 Report Share Posted February 16, 2012 You sure you have spark then? If you have spark and fuel then it should start lol check your earths. Link to post Share on other sites
ashmk3 0 Posted February 16, 2012 Report Share Posted February 16, 2012 Is it obd1 or 2 ? If it's 1 check maf is plugged in, isv. Throttle body plugged in? Just trying to think of all things inlet related. If its turning over then the starter must be working and if your sure there's spark then there getting power so I would say the battery move seems ok. Have you earthed the engine at all through the gearbox? Link to post Share on other sites
baz8328 0 Posted February 16, 2012 Author Report Share Posted February 16, 2012 Its. Obd1 and yes I will check all sensors tomorrow Why is no one near scunny who could help lol Link to post Share on other sites
Daverse 175 Posted February 17, 2012 Report Share Posted February 17, 2012 bit late but i am available from 2 today? Link to post Share on other sites
baz8328 0 Posted February 17, 2012 Author Report Share Posted February 17, 2012 Awesome !Text me on 07921 519734 gonna be over the weekend ! Link to post Share on other sites
ashmk3 0 Posted February 17, 2012 Report Share Posted February 17, 2012 I'm also obd1 and the car will not start or run without the maf plugged in. Hope you sort it. Link to post Share on other sites
baz8328 0 Posted February 20, 2012 Author Report Share Posted February 20, 2012 2 coilpacks later and she burst into life !My love for the vr6 is back ! Link to post Share on other sites
Daverse 175 Posted February 20, 2012 Report Share Posted February 20, 2012 Did you get a new one then mate? Link to post Share on other sites
michael5556 247 Posted February 20, 2012 Report Share Posted February 20, 2012 If you have a spare/bracken one I need half of one to fix mine? Glad you got it sorted. Link to post Share on other sites
