cbmotorsport 0 Posted December 5, 2011 Report Share Posted December 5, 2011 WILL AN ADMIN PLEASE MAKE THIS A STICKY!!! Here is full pin data for a mk3 CE2 fusebox used in the gti,vr6 and pretty much every other engine. Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light, rear wiper 15 5 Wiper/washer 15 6 Fresh air blower, Air conditioning 20 7 Rear light, sidelight, right 10 8 Rear light, sidelight, left 10 9 Rear window defogger 20 10 Fog lights 15 11 Headlight, high beam, left, High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn, 16-valve only: Radiator cooling fan 10 14 Reverse lights, heated washer jets 10 15 Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, MFA 15 17 Hazard switch, indicators 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, dash clocks, boot light, central locking 15 22 Radio, cigarette lighter 10 Relay No. Description 1 Air conditioning 2 Rear Wiper 3 ECU relay 4 Load reduction/x-over relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Headlight washers 8 Intermittent wipers 9 Seat belt/lights on warning relay 10 Fog lights 11 Horn 12 Fuel pump (fuel injection) Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve) 2.0 16-valve: Starter interlock relay 14 Automatic gearbox, coolant temperature indicator, starter interlock relay (except 2.0 16-valve) 2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or Electric seat circuit breaker 19 Automatic gearbox 20 Open 21 Electric window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Electric window fuse Connections and plugs on rear of fuse/relay panel:A1 Yellow 8 pin Headlight wiring harness A2 Yellow 8 pin Headlight wiring harness B Green 6 pin Headlight washer wiring harness C Yellow 8 pin Headlight or wiper motor wiring harness D Green 12 pin Miscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.) E Green 5 pin Instrument or brake light wiring harness F White 10 pin Engine compartment/engine management, wiring harness, right side (position 10 open) G1 White 12 pin Engine compartment/engine management, right side G2 White 12 pin Engine compartment/engine management, right side (position 12 open) H1 Red 10 pin Steering column switch wiring harness H2 Red 8 pin Steering column switch wiring harness (position 8 open) J Red 10 pin Steering column switch wiring harness K Black 12 pin Rear wiring harness L Black 8 pin Rear/Parking brake wiring harness (position 8 open) M Black 6 pin Rear/fuel tank wiring harness N Green 6 pin Air conditioning wiring harness P Blue 10 pin Rear window defroster/fog light wiring harness Q Blue 6 pin Fresh air blower fan wiring harness (position 10 open) R Blue 10 pin Light switch wiring harness S White 5 pin Engine compartment/wiper motor wiring harness, right side T Green 2 pin Individual circuits U1 Blue 14 pin Instrument cluster wiring harness U2 Blue 14 pin Instrument cluster wiring harness V Green 4 pin Steering column switch Multi-function indicator wiring harness W Green 6 pin Miscellaneous optional equipment, varies with vehicle type X Green 8 pin Warning lamp wiring harness Y n/a 1 pin 4 single point connectors for terminal 30 circuit (some may be bridged with red connector) Z1 n/a 1 pin Single point connector Z2 n/a 1 pin Single point connector for terminal 31 circuit 30 n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30B with red connector) 30B n/a 1 pin Single point connector (may be bridged to 30 with red connector) Golf MK3, CE2 Fusebox:30-30b - red- bridged (power for fuel pump relay)A11 - yel/wht - left headlight pin 2 (dipped beam)2 - blk/wht - front left indicator, alarm system control module pin 1, dash plug pin 22 (left indicator light)4 - gry/blk - front left indicator & parking lights5 - red - rad fan thermal switch pin 36 - wht/blk - left headlight pin 1 (main beam)7 - blk/yel - horn(s) pin 28 - brn/blk - horn(s) pin 1A22 - front right indicator & parking lights3 - yel - right headlight pin 2 (dipped beam)4 - blk/grn - front right indicator, alarm system control module pin 2, dash plug pin 24 (right indicator light)7 - wht - right headlight pin 1 (main beam)8 - gry/yel - rear fog lightsC1 - blu/brn - brake fluid warning switch pin 12 - grn/red - washer motor pin 17 - brn/blu - washer motor pin 28 - blu/red - coolant level sensor pin 2D3 - blk/red - glovebox light pin 28 - blk - ignition coil, ECU pin 38, vehicle speed sensor pin 1, Junction connector TV4, airbag control unit pin 129 - blk/wht - Junction connector TV511 - blk/blu - Junction connector TV512- gry/blu - Junction connector TV8E2 - blk - Junction connector TV43 - blk/red - brake light switch pin 14 - red/yel - brake light switch pin 2F1 - red - alarm control unit pin 5, ECU pin 7, park/neutral position switch, starter motor pin 503 - blu - alternator pin D+4 - brn - vehicle speed sensor pin 36 - blk/red - reverse light switch pin 2- blk - Park/Neutal position relay pin 57 - blk blue - reverse light switch pin 1G12 - brn/wht - outside air temp sensor3 - yel/blu - ECU pin 64 - blk - ECU pin 38, gearbox speed sensor, ignition coil pin 35 - brn/wht - earthed to engine block6 - brn - heated washer jets- brn/red ECU pin 12 (1.8L)7 - blk/brn - ECU pin 98 - red/yel - lambda probe pin 29 - yel/blk - ECU pin 510- red/blu - ECU pin 23, cam position sensor pin 3, evap canister purge valve, maf sensor pin 3, lambda probe pin 6, EGR valve, fuel injectors11- wht/blu - vehicle speed sensor pin 212- grn/blk - ECU pin 22G21 - grn/blk - oil temp sensor2 - wht/red - outside air temp sensor3 - blu/wht - coolant temp sender4 - blk/pur - ECU pin 38 (ABF), carbon canister, isv, breather heater10- yel - high oil pressure warning switch11- blu/blk - low oil pressure warning switchH11 - red/blk - ignition switch pin 502 - red - ignition switch pin 303 - blk/yel - ignition switch pin X4 - blk - ignition switch pin 155 - blk/blu - indicator stalks 4pin plug pin 46 - brn - wiper stalk 4pin plug pin 37 - brn/red - ignition switch pin S, radio pin 48 - grn/red - wiper stalk 4pin plug pin 29 - grn/wht - wiper stalk 4pin plug pin 1H21 - brn/blu - indicator stalk 7pin plug pin 14 - blk/grn - indicator stalk 7pin plug pin 76 - blk/wht - indicator stalk 7pin plug pin 38 - blk/wht/grn - indicator stalk 7pin plug pin 2J1 - wht - indicator stalk 5pin plug pin 42 - wht/blk - indicator stalk 5pin plug pin 33 - yel - indicator stalk 5pin plug pin 2- yel/blu - DRM relay resistor?4 - red/yel - indicator stalk 5pin plug pin 55 - grn - wiper stalk 5pin plug pin 36 - brn/blk - wiper stalk 5pin plug pin 57 - blk/gry - wiper stalk 5pin plug pin 28 - wht/yel - indicator stalk 5pin plug pin 19 - grn/blk - wiper stalk 5pin plug pin 410- grn/yel - wiper stalk 5pin plug pin 1K1 - blk/wht - rear left indicator2 - gry/red - right rear lights, fusebox pin L/33 - gry/blk - left rear lights, fusebox pin L/44 - red/blk - brake lights5 - gry/grn - rear number plate lights, rear ashtray light6 - blk/yel - rear wiper motor pin 17 - blk/grn - rear right indicator8 - blk/blu - reverse lights9 - grn/blk - rear wiper motor pin 311- brn - rear ashtray light, 'earth claw'?12- wht - rear screen heaterL1 - brn - handbrake warning switch pin 22 - brn/yel - Junction connector TV173 - red/blk - fusebox pin K/24 - gry/blk - fusebox pin K/35 - red/blk - boot light6 - brn - handbrake warning switch pin 17 - red/blk - electric sunroof control module pin 5, sunvisor mirror light, front & rear interior lights, central locking control module pin 1M1 - brn - fuel pump2 - red/yel - fuel pump3 - vio/blk - fuel level sender5 - blk/wht - sunroof light switch pin 1, right front map/reading light6 - brn/blu - fuel level senderP1 - gry/yel - fog light switch pin 83a2 - blk/yel - rear window heater switch pin 43 - wht/grn - rear window heater switch pin 3, heated mirror elements4 - gry/blu - fog light switch pin 835 - brn - rear screen heater switch pin 317 - gry/blu - rear screen heater switch pin 1Q1 - brn - glovebox light pin 1, boot light pin 2, cigarette lighter pin 1, A/C switch pin 3, blower light pin 2, diagnostics plug pin 1, boot release switch pin 22 - blk/red - bridged to N/6, Blower switch pin 2, coolant control module 8pin plug pin 4, A/C thermal switch/engine coolant temp warning switch pin 23 - red/wht - cigarette lighter pin 2, radio pin 7, boot light switch pin 1, diagnostic connector pin 2, boot release switch pin 16 - gry/blu - blower switch pin 1, A/C switch pin 5, cigarette lighter pin 3, radio pin 6R2 - gry/blk - headlight switch pin 58L4 - brn - headlight switch 58b5 - red/yel - headlight switch pin 116 - gry/red - headlight switch pin 58R7 - gry/grn - headlight switch pin 588 - brn - headlight switch pin 319 - wht/blk - headlight switch pin 210- blk/yel - headlight switch pin X, DRM relay pin 4S1 - blk/gry - wiper motor pin 1, heated washer jets2 - grn - wiper motor pin 43 - brn - wiper motor pin 54 - grn/blk - wiper motor pin 35 - grn/yel - wiper motor pin 2U11 - wht - Dash plug pin 17 (oil temp sensor)2 - wht - Dash plug pin 19 (outside temp sensor)3 - wht - Dash plug pin 8 (oil pressure control unit - feed from 1.8 bar)5 - wht - Dash plug pin 9 (oil pressure control unit - feed from 0.3 bar)6 - wht - Dash plug pin 10 (rev counter)7 - wht - Dash plug pin 1 (outside temp sensor)10- wht - Dash plug pin 3 (earth)11- wht - Dash plug pin 27 (speedo signal)12- wht - Dash plug pin 21 (fuel gauge)14- wht - Dash plug pin 12 (dash & digital clock bulbs)U21 - wht - Dash plug pin 13 (ignition live feed)2 - wht - Dash plug pin 7 (cruise control unit pin 5, 2.0 16v motronic control unit pin 2?)4 - wht - Dash plug pin 15 (stalk memory switch pin 2)5 - wht - Dash plug pin 2 (coolant low level sender)7 - wht - Dash plug pin 25 (main beam warning light)8 - wht - Dash plug pin 6 (stalk memory switch pin 3)9 - wht - Dash plug pin 23 (coolant temp gauge)10- wht - Dash plug pin 18 (handbrake warning light)11- wht - Dash plug pin 11 (permanent live feed from fuse #21)12- wht - Dash plug pin 16 (alternator warning light)13- wht - Dash plug pin 5 (earth to cylinder head)14- wht - Dash plug pin 4 (stalk memory switch pin 4)V1 - red/wht - MFA mode select switch2 - brn/wht - MFA switch earth3 - blu/yel - MFA switch memory select/reset4 - yel/red - MFA switch memory select/resetW1 - blu/wht - vehicle speed sensor junction connector2 - gry/blk - ABS relay pin 3, ABS module pin 524 - wht/red - ABS module pin 32- blk/red - Cruise control clutch & brake pedal switch pin 1, transmission control module pin 26X2 - blk/yel - airbag control light pin 4, ABS warning pin 24 - blk/yel - airbag control light pin 28 - yel/red - ABS warning light pin 1Y1 - brn/blu glow plug timer module pin 52 - electric windows, park/neutral psition relay pin 23 - Red - Battery +ve, Junction connector TV2Z1 - red - fuel injectorsZ2 - brn - battery negativeJunction connector TV2: (live, unfused)alarm control module 6pin plug pin 3alarm control module 10pin plug pin 1left/right central locking trigger motors pin 2alarm/central locking/boot lock switch pin 4alarm system indicator light pin 2left/right door warning lights pin 2ECU pin 54fuel evap relay pin 2Junction connector TV4: (Ignition live, from coil -15)E/2D/8alarm module 10pin plug pin 4shift lock solonoid pin 2transmission control module pin 19cruise control/transmission range switch pin 5Airbag control module pin 5cruise control range switch pin 5Transmission control module pin 23Junction connector TV5: (Ignition live, from coil -15)D/9D/11cruise control/transmission range switch pin 4left/right rear electric window switches pin 1A/T console lightcassette storage lighttransmission control module pin 38electric mirror switch pin 6heated seat switch pin 3heated seat control modules pin 8electric window control modules pin 7PCV heaterJunction connector TV6: (Ignition live, from x-over relay -X)D/3Coolant fan control module T10a/93rd speed coolant fan switch pin 2A/C pressure switch pin 4Junction connector TV8: (Dash lights feed)D/12heated seat switch pin 1electric mirror switch pin 2front electric window switches pin 1electric window switch console pin 4cruise control transmission range switch pin 4A/T console lightJunction connector TV11: (Brakes on feed)W/4Diesel DFI ECU pin 44Junction connector TV13: (Vehicle speed sensor)W/1cruise control module pin 7ECU pin 65Junction connector TV17: (Drivers door open earth)L/2drivers door switch pin 1Junction connector TV18: (Ignition live, from x-over relay -X)D/3ABS control module pin 23 __________________Hope this helps Link to post Share on other sites
michael5556 247 Posted December 5, 2011 Report Share Posted December 5, 2011 Very usefull! Link to post Share on other sites
Daverse 175 Posted December 5, 2011 Report Share Posted December 5, 2011 very useful, ive got these pictures plastered all round the footwell Link to post Share on other sites
