VR mocal onto R32
Why don't you just try it? You'll soon get your answer.
Technically the R32 and 12V blocks are completely different, but the OE heat exchanger fittings are the same, so your Mocal will probably work.
Do you actually need it though? My R32 uses the 12V heat exchanger and it the oil and water don't get anywhere near as hot as the 12V used to.
