Ive searched But I can not find any info on.
Which is the IGN_12V wire.
Im trying to run wires for my Accuair Ride suspension And I need to run two wires up front.
1-IGN_WIRE. ( Is it that thick black one ? )
2-Headlights. ( No idea where this one is)
I have wires ready up front,Plastic cover around steering wheel is off But I have no idea which wire is which PLZ I need help.
Surely the headlight wire will be in the headlight switch?. And I think you might find that the Black wire is and earth, but can you not use a voltage meter to check which wire you need. Are you after a permanent live, or one thats only live when you switch on the ignition? Also wouldn't you be better off using the fuse box to route wires to and from??? Just a few thoughts...
Im a total Noob to this kind of stuff as you can tell.
About the Headlight Switch think your right on that one I Was thinking the same.
I need One thats only live when I switch on the Ignition,
Theres soo many wires in there !!
Ill have to invest in a voltage meter If I cant get help soon.
