faigolfgti 0 Posted September 19, 2011 Report Share Posted September 19, 2011 My vw golf mk3 vr6 came with 280mm front brake disc and i plan to upgrade to the later 288mm front brake disc,my question is is it going to improve alot of braking performance if i upgrade to 288mm front brake disc?Is it wort the effort for that little gain?Thank You. Link to post Share on other sites
russj249 2 Posted September 19, 2011 Report Share Posted September 19, 2011 It's not just the size. if you put the 280 and 288mm pads together there's a lot lot more surface area on the 288's.more braking surface area means more friction, but more friction means more heat so go for a good pad or you might risk brake fade.hope this helps. Link to post Share on other sites
faigolfgti 0 Posted September 20, 2011 Author Report Share Posted September 20, 2011 What i meant is by upgrade to 288mm front brake disc if the braking performance is improve a little bit than it is not worth the effort,i would like the member in this forum who have done the project to advise me.Thank You. Link to post Share on other sites
legvw 0 Posted September 20, 2011 Report Share Posted September 20, 2011 Yes the braking will improve a little, but if you want better brakes, then maybe a 312mm conversion? There is a guide on here.I found the 280 brakes really poor, along with the abs system, which both nearly left me in various hedges!!! (this was when me car was relatively standard) Link to post Share on other sites
spadam 7 Posted September 20, 2011 Report Share Posted September 20, 2011 I noticed quite a diffrecne when i fitted the 288s to mine mainly due to the size diffrence in the pads also the calipers are also bigger. I agree with paul about abs and i really dont like it on my 4mo. Link to post Share on other sites
