Hi all, just a quick question, Im gonna buy some of those cheap bbs copies and wondered if i'd be ok putting 9s on the front as well as the rear. 7.5s just arent wide enough. The arches are gonna be rolled and pulled etc. Will they look daft? will they rub? what offset is recommended? thanks. 16" by the way.
yeah you can do 9's on the front - tyres would need to be either 215/35 or 195/45 I would think you will defo need to do some archwork - rolled or flared whatever especially if your car is low,add a bit of camber to them too and as for offset something around the original of 35 or a little more so the wheel will sit further into the arch but then you risk inner arch scrubbing !!
