VDub_Steve 1 Posted May 27, 2011 Report Share Posted May 27, 2011 hey got a problem clutch has started to slip my question is as the clutch has only done 10.000 miles could i just replace clutch or do i need to replace pressure plate and release bearing also Link to post Share on other sites
VR6Pete 1,455 Posted May 27, 2011 Report Share Posted May 27, 2011 Are your hydraulics ok? I assume you replaced with a clutch kit 10k ago? Link to post Share on other sites
VDub_Steve 1 Posted May 27, 2011 Author Report Share Posted May 27, 2011 i presume so i can drive car normally and select gears normally! Only slips when in a gear higher then 3rd and on full throttle also biting point is quite close to the top of the peddle and yes clutch was replaced along with pressure plate and release bearing Link to post Share on other sites
VDub_Steve 1 Posted May 27, 2011 Author Report Share Posted May 27, 2011 . Link to post Share on other sites
VR6Pete 1,455 Posted May 27, 2011 Report Share Posted May 27, 2011 very strange - how do you drive the car? I suppose a visual inspection is required to determine the cause. Link to post Share on other sites
VDub_Steve 1 Posted May 27, 2011 Author Report Share Posted May 27, 2011 i did drive it hard sometimes but it was a stage 3 6 puck Link to post Share on other sites
