michael5556 247 Posted May 10, 2011 Report Share Posted May 10, 2011 As I was just driving to work my car developed a knocking noise when turning or slowing down, I am thinkin either cv joint or engine mount? It didn't do it when accelerating.Any ideas? Link to post Share on other sites
Bigjobbo 0 Posted May 10, 2011 Report Share Posted May 10, 2011 Could be the CV, may also be ball joint, t.r.end.wishbone bush, arb link etc. CV's make a very distinct noise and more noticable on full lock. Link to post Share on other sites
michael5556 247 Posted May 10, 2011 Author Report Share Posted May 10, 2011 I also think the top mounts may be on their way so could it be them or would that only be on full lock? Link to post Share on other sites
bungy 2 Posted May 10, 2011 Report Share Posted May 10, 2011 Top mounts tend to be noticeable at slow speed on an uneven road. Driving slow on full lock is usually drive shaft / CV. Link to post Share on other sites
michael5556 247 Posted May 10, 2011 Author Report Share Posted May 10, 2011 Ok will check later on or tomorrow, thanks for the help guys Link to post Share on other sites
DanH 1 Posted May 10, 2011 Report Share Posted May 10, 2011 dont think it will be top mounts...mine were rubbing on bonnet before i changed them didnt knock tho.... Link to post Share on other sites
michael5556 247 Posted May 10, 2011 Author Report Share Posted May 10, 2011 Knocking got worse on way home from work, but it does not do it when turning, only way driving, mostly when slowing down. It's not engine mounts, could be top mounts or a bushing, sounds like it is bouncing up at down with nothing cushioning it. Will jack it up tomorrow and have a look. Link to post Share on other sites
tjsmudger 2 Posted May 10, 2011 Report Share Posted May 10, 2011 Is it safe enough to drive around? Link to post Share on other sites
michael5556 247 Posted May 10, 2011 Author Report Share Posted May 10, 2011 Not sure, it doesn't sound good so probably going to try and leave it unless necessary Link to post Share on other sites
michael5556 247 Posted May 11, 2011 Author Report Share Posted May 11, 2011 Now think it's driveshaft as it seems to get faster the faster I drive. Don't see what else it could be Link to post Share on other sites
tjsmudger 2 Posted May 11, 2011 Report Share Posted May 11, 2011 Could be a c.v joint, I had what sounds like this last year, was a pain in the rectum. When it was replaced the whole joint had snapped off! And there was me flooring it down the motorway only the day before! Makes you think! Link to post Share on other sites
michael5556 247 Posted May 12, 2011 Author Report Share Posted May 12, 2011 Yeah I am thinking it's a joint, but which one ? Lol hard to find out. Shall I just replace the drive shaft or take it apart and just do the joint? Luckily for me the engine is coming out next week anyway and going in the mk2 so could just do it then Link to post Share on other sites
tjsmudger 2 Posted May 12, 2011 Report Share Posted May 12, 2011 I watched my pal undo the wheel then loosen the wheel bearing and it literally fell off! That's where mine snapped. Link to post Share on other sites
tjsmudger 2 Posted May 12, 2011 Report Share Posted May 12, 2011 The driveshaft on mine was fine, just the cv joint Link to post Share on other sites
michael5556 247 Posted May 12, 2011 Author Report Share Posted May 12, 2011 I might just replace the whole thing incase it decides to break Link to post Share on other sites
