thobo 0 Posted May 7, 2011 Report Share Posted May 7, 2011 Brakes are basically going to the floor if I apply gradual pressure to themHad a look over and there is something leaking just infront of the passenger side rear wheel, i assume this is something to do with it. Can someone just confirm what this is? Link to post Share on other sites
Nero Mk 2 8 Posted May 7, 2011 Report Share Posted May 7, 2011 Possibly Brake fluid?just a guess Link to post Share on other sites
thobo 0 Posted May 7, 2011 Author Report Share Posted May 7, 2011 Topped it up, doesnt seem to do anything. But I'm guessing that it is a leak of the fluid as its coming out where I said. Although the rear near side brake line doesnt connect to it Link to post Share on other sites
VR6Pete 1,455 Posted May 7, 2011 Report Share Posted May 7, 2011 Could be brake bias valve, sounds like you need to get underneath it to see where the leak is coming from, could be corroded lines, or knackered brake hose... Link to post Share on other sites
thobo 0 Posted May 7, 2011 Author Report Share Posted May 7, 2011 Had a good look under the car, turns out its a brake line which has the smallest of cracks in it but pisses out fluid when you brake. Are these ok to weld up? The crack is tiny so would seem unecessary to completely replace it at expense Link to post Share on other sites
VR6Pete 1,455 Posted May 7, 2011 Report Share Posted May 7, 2011 Replace the line, if its cracked already, who's to say that other parts of the line have become weakened... With brakes being probably the biggest thing in regards to safety the last thing I would do the job properly and replace the whole line... it shouldn't be that expensive to have a single line made up... as there would be a lot of pressure in the lines once your stamping on the brakes, the last thing you want happening is for your foot to hit the floor when your doing 60MPH and you need to brake.Please don't 'bodge' the line for the sake of yourself and any passengers that go in your car Pete Link to post Share on other sites
Gazbarber1982 3 Posted May 7, 2011 Report Share Posted May 7, 2011 Cost me £15 for a full kit off eBay for brake lines, olives, fittings and flaring kit. Took me less than an hour to make up new lines when I changed to braided hoses. Link to post Share on other sites
thobo 0 Posted May 7, 2011 Author Report Share Posted May 7, 2011 Yeah I suppose I should get them replaced, going to need to pay over the odds though, need the car for work on Monday so having to take it to the only garages open on Sundays....Kwik-Fit and F1 autocentre! Pricey bill here we come fingers crossed they'll be able to do it though Link to post Share on other sites
Gazbarber1982 3 Posted May 7, 2011 Report Share Posted May 7, 2011 Worth it though. Apart from good tyres (which other people would also recommend) brakes are the only thing gonna stop you from hitting anything! No point having power if you can't stop it!! Link to post Share on other sites
