Good garage in Wiltshire.
Thanks for your reply Bungy. I have a strange noise coming from the left front of the engine that no-one has been able to diagnose so I would like to take it somewhere where they know the VR6 engine.
Also I have wondered whether running diagnostic software might throw something up?
Front left as you look at it with bonnet open or when in the car could be either belt tensioner or timming chains. These make funny noises when there on there way out.
Front left when you look at it with the bonnet open. The belt tensioner is fine. Me and a mechanic friend took out the air box and removed the belt and checked all the pulleys and everything is fine inc. the tensioner pulley bearing. The water pump was replaced a month ago.
It only makes the noise when up to temp and only when the engine is idling. It hasn't effected the performance or engine temps in any way. It sounds like a bearing but I now know it's not. It's so hard to locate where it's coming from!
I'm in Southampton at J7 of the M27. I can do a scan of your car and there is no charge if it helps. I have a fair idea of what it might be but i'd have to hear it.
According to Google maps you are less than 60 miles away so I may well take you up on your offer, thanks. All the local garages seem to want at least 1/2 hour labour just for diagnostics. As you clearly know your stuff it'll be worth the blast down! I'll PM you to discuss further if that's cool.
