cornishvr6 52 Posted March 18, 2011 Report Share Posted March 18, 2011 In the next couple of months im having some bodyshop work done and on my list is to replace the aerial base as mine is in the process of either nibbled by a cat or disintegrating, Is there any other options to replace it with? e.g a newer vw/audi etcCheers Link to post Share on other sites
HAMMER_VR6 0 Posted March 18, 2011 Report Share Posted March 18, 2011 Do you just want to change the rubber washer, or the aerial itself?You could probably stick any bee-sting on, they are all similar fitting. Link to post Share on other sites
cornishvr6 52 Posted March 19, 2011 Author Report Share Posted March 19, 2011 Do you just want to change the rubber washer' date=' or the aerial itself?You could probably stick any bee-sting on, they are all similar fitting.[/quote']The whole base really Link to post Share on other sites
HAMMER_VR6 0 Posted March 19, 2011 Report Share Posted March 19, 2011 If you remove the old one you will be left with a small hole. probably about 10mm, so providing your new aerial is the same fitting anything goes. Or you could flush the hole and have a hidden areial like some modern cars Link to post Share on other sites
bungy 2 Posted March 19, 2011 Report Share Posted March 19, 2011 I have a BMW shark fin aerial in mine. Link to post Share on other sites
