Hi there....
They run well with mods or no mods to be honest, however with each mod you will have to get the ECU remapped. coupled with cams and a schrick VGI, you will be running some nice power...... 270BHP + I recon with cams and VGI...
not many standard VR6's run at 174BHP to be honest so you will will probably find with a good map you will be well into to 250BHP region.
Reliable.... depends on how hard you drive it!
1. You can use it with a Schrick Vgi or standard manifold. 256, 248 or stock cams would work well an s/c. Cams are more for mid range torque than peak power.
2. Stage 1 (6 psi) should give 250-270 hp, 230-240 lb ft torque. Perhaps a bit more with vgi, cams and a remap.
3. They are pretty reliable. I've covered 30k miles with no issues.
