richgti97 0 Posted February 22, 2011 Report Share Posted February 22, 2011 hi all, a while ago my vr overheated its oil and was leaking coolant and was really rattley (tappy) on the top end. only just got around too checking it out. Thought it was headgasket but upon removing the the head the gasket was fine..? have found a small leak from one of the oil cooler-block pipes.. i am going too replace the headgasket and get head skimmed now that i have removed it.. but i cant think of why the engine was rattley? could the oil just have been knackerd and this is wat caused the noise because im stuck for suggestions otherwise? any help/pointers would be helpfull thanks! Link to post Share on other sites
VR6Pete 1,455 Posted February 22, 2011 Report Share Posted February 22, 2011 hyrdolic lifters? or your using too thin oil... what are you using in it? Link to post Share on other sites
richgti97 0 Posted February 22, 2011 Author Report Share Posted February 22, 2011 was using 10/40 from vw.. it ran ok on it for quite a while tho.. altho was bit tappety now and again but once it cooked the oil the oil temp rose too bout 140 after bout 10mins. Link to post Share on other sites
jims13 6 Posted February 23, 2011 Report Share Posted February 23, 2011 have you checked the standard oil cooler , these can fail Link to post Share on other sites
jims13 6 Posted February 23, 2011 Report Share Posted February 23, 2011 failing that a starved / faulty oil pump , or blocked strainer in the sump Link to post Share on other sites
richgti97 0 Posted February 23, 2011 Author Report Share Posted February 23, 2011 I have visually checked the cooler and looks fine but no way of telling if its doing its job. And the oil pressure is at 3-5bar so im assuming the oil pump etc..are ok aswell.? Link to post Share on other sites
markiev6 1 Posted February 24, 2011 Report Share Posted February 24, 2011 put money on it being oil cooler you cant tell by looking at it had same prob few years ago Link to post Share on other sites
richgti97 0 Posted February 27, 2011 Author Report Share Posted February 27, 2011 anyway of checking the cooler or jus a case of gettin a replacement? Link to post Share on other sites
