TEDVR6 0 Posted January 23, 2011 Report Share Posted January 23, 2011 HI ALL, JUST WONDERED IF ANY ONE COULD HELP ME ON A FEW QUERIES I HAVE. FIRSTLY, I HAVE BEEN READING ON HERE ABOUT AUX WATER PUMPS, AND IT APPEARS THAT MINE MAY NOT BE WORKING. I NEVER SEEM TO HEAR THIS RUNNING ON NOISE PEOPLE ARE TALKING ABOUT WHEN I SWITCH THE CAR OFF, IS THIS GOING TO CAUSE ME ANY TROUBLE?? SECONDLY, MY ENGINE HAS A BIT OF A RATTLE WHEN IT IS COLD, MAINLY FROM AROUND THAT AUX WATER PUMP AREA, POSSIBLY TIMING CHAIN AREA, PARTICULARLY BETWEEN 1000RPM TO 2000RPM, BUT THIS GOES AWAY AFTER A MIN OR TWO, SOMETIMES LESS. ANY THOUGHTS??AND FINALLY, I DONT KNOW WETHER THIS IS JUST THE TYPE OF THESE VR6'S, BUT CAR DOESNT SEEM OVERLY POWERFUL LOW DOWN THE REVS, WHEN I SINK THE BOOT IS DOESNT SEEM TO REV TOO QUICKLY TO 3000RPM OR SO, BUT THEN WHEN IT REACHES 3500-4000 IT SEEMS TO TAKE OFF LIKE HELL, LIGHTS THE TYRES UP THEN NEXT THING YOUR LOOKIN FOR ANOTHER GEAR. YOU WOULD THINK IT HAD LIKE A HONDA VTEC FEELING TO IT NEARLY. ANY WAYS OF OVERCOMING THIS OR IS THIS JUST THE BREED OF THE BEAST???LOLANY HELP ON EITHER OF THESE 3 SMALL ISSUES WOULD BE GREATLY APPRECIATED. HAD MY FIRST VR6 FOR FEW WEEKS NOW AN THINK ITS AMAZING. GREAT CAR. THIS IS MY FIRST POST ALSO, WOULD BE GREAT TO HEAR YOUR THOUGHTS. CHEERS, TED Link to post Share on other sites
gaz.veedub 0 Posted January 23, 2011 Report Share Posted January 23, 2011 cant help on the other things mate but as for the car slugging it at low revs thats just the way they are 3000rpm up pulls like a train any lower and the dont pull the same.well thats my experience of them any way;) Link to post Share on other sites
CALICO 130 Posted January 23, 2011 Report Share Posted January 23, 2011 A scrick inlet manifold helps to overcome the low end bogging but they are expensive. Link to post Share on other sites
VR6Pete 1,455 Posted January 23, 2011 Report Share Posted January 23, 2011 You could start by changing the hydrolic bolt to see if that helps with the rattle on the timing chains. Link to post Share on other sites
probert993 0 Posted January 23, 2011 Report Share Posted January 23, 2011 in regards to your pump i have just changed mine for brand new one when u turn key all way just before u start car u should he water pumping around also if u feel the hoses from the pump you should feel water runnin through , also after every run when key is out water should continue to run , in regards to problems it can cause problems over time , the run on pump stops hot spots forming after turn off also primer engine prior to start up, also have heard of occasions where heater matrix has been damaged, end of the day vw fitted it for a reason so should work correct, i got new one from gsf 84 quid , easy to fit mine all working great now , hope this helps let me know . . . Link to post Share on other sites
bungy 2 Posted January 23, 2011 Report Share Posted January 23, 2011 It's a big engine with a heavy flywheel and so will not rev so easily from low down but as it gains momentum then the power takes over. Link to post Share on other sites
