wag 0 Posted January 14, 2011 Report Share Posted January 14, 2011 well i seem to have a setup sitting up the barn and was wondering if anyones running these and get some feed back?i have discs pads calipers and carriers all i need is flexis and bolts for the carriers or is there anything else i need?? Link to post Share on other sites
legvw 0 Posted January 14, 2011 Report Share Posted January 14, 2011 You may find you need a spacer between the carrier and the hub, i did when i installed mine. I think it was 6mm.Very good brakes on a mk3, but the discs and pads are quite expensive, but then they are huge!! Link to post Share on other sites
wag 0 Posted January 14, 2011 Author Report Share Posted January 14, 2011 ok cool thanks mate i was wondering about the spacer as i know u need them for the tt setupdiscs and pads are almost new so be a while till i need some new oneswhat flexis are u using Link to post Share on other sites
legvw 0 Posted January 14, 2011 Report Share Posted January 14, 2011 Because i'm running r32 front and rear brakes, i just bought a goodridge hose set for an r32. Link to post Share on other sites
richievr 1 Posted January 14, 2011 Report Share Posted January 14, 2011 will they fit under 17's?? or do you need 18's to clear them?? Link to post Share on other sites
CALICO 130 Posted January 14, 2011 Report Share Posted January 14, 2011 no they fit under 17's or at least some 17's Link to post Share on other sites
wag 0 Posted January 14, 2011 Author Report Share Posted January 14, 2011 thanks for ur help guys looks like ill be doing this nxt weekend whts best to do with there rear brakes as my calipers are half seized Link to post Share on other sites
finny 0 Posted January 14, 2011 Report Share Posted January 14, 2011 When one of my rear brake calipers seized, went for Mk4 calipers, just need new hoses to fit, but went whole hog changing discs, bearings etc.Believe there are large rear discs conversions but don't think its necessary unless for looks? Link to post Share on other sites
wag 0 Posted January 14, 2011 Author Report Share Posted January 14, 2011 what discs do u use for the large conversions? i have some vented anni golf ones sitting around but as the mk3 has inbuilt bearings couldnt think of what to use Link to post Share on other sites
legvw 0 Posted January 14, 2011 Report Share Posted January 14, 2011 no they fit under 17's or at least some 17's Yes they do, i was running 17" santa monicas, and now i've got 17" tt ronal alloys, both fit over the brakes. I think its some after market wheels you have to be careful with. Link to post Share on other sites
