mk3_matt 21 Posted November 14, 2010 Report Share Posted November 14, 2010 hi ive just done a engine conversion in my mk3 golf the vr6 engine ran fine before i removed it but now when i start it it doesnt seem 2 wanna stay started ive check the fuel pump thats fine... the old car had a alarm on it but when i removed the loom i disconnected it all out ... any body had this trouble before anythink i can test.... ive hit a brick wall and just wanna drive the car but cant..thanks matt Link to post Share on other sites
UnitedMotorsport 55 Posted November 14, 2010 Report Share Posted November 14, 2010 What is the part number of the ECU? It may be the internal immobilizer. Link to post Share on other sites
mk3_matt 21 Posted November 14, 2010 Author Report Share Posted November 14, 2010 Ill check that 2morra can I put a different ecu on it then and that will make it run Link to post Share on other sites
p0u1 14 Posted November 15, 2010 Report Share Posted November 15, 2010 dose it start and run for about 3 secounds every time because thatss what mine done affter the swap, i had to get the immobilizer removed, talk to UnitedMotorsport, they can remove it, also if you can use vagcom it will tell you if it is the imobiliser stopping it from running Link to post Share on other sites
mk3_matt 21 Posted November 15, 2010 Author Report Share Posted November 15, 2010 the part number is 021 906 258 ch hope thats any good for you .... Link to post Share on other sites
UnitedMotorsport 55 Posted November 15, 2010 Report Share Posted November 15, 2010 258CH has an internal immobilizer - Did you use the black box and the key from the donor car? Link to post Share on other sites
mk3_matt 21 Posted November 15, 2010 Author Report Share Posted November 15, 2010 Yer I did what do you suggest now then Link to post Share on other sites
UnitedMotorsport 55 Posted November 15, 2010 Report Share Posted November 15, 2010 We can remove the immo from your ECU if you send it to us.http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?364251 Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Wicked what sort of cost is involved and were u based Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Last nite I unplug the ecu 2 get the part number of off it then plug it in 2day and the car ran fine no problems then I turned it off then bout 10 mins later went 2 start it up same problem again does this still sound like ecu immobiliser 2 u also if I try a obd1 ecu will it work ok Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2010 Report Share Posted November 16, 2010 Your ECU is OBD1!Defo is an immo problem you have there. Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Fort it was obd2 my car has a coil pack so any ideas wat 2 check Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2010 Report Share Posted November 16, 2010 258CH Is an OBD1 ECU.Sounds like the black immo box has thrown its toys out of the pram. Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 So if I put anova obd1 ecu on it it sud b ok by the sounds of it lol Sorry 2 ask suck silly questions thanks for all the help tho Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2010 Report Share Posted November 16, 2010 No. You will have the same problem! Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 What do u suggest then matey Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2010 Report Share Posted November 16, 2010 Removing the immobilizer from the ECU. Link to post Share on other sites
mk3_matt 21 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Ok kwl what's the process then do I send it 2 u with cheque in the post Link to post Share on other sites
UnitedMotorsport 55 Posted November 16, 2010 Report Share Posted November 16, 2010 Can do, Using paypal will be quicker though. Link to post Share on other sites
VR6Wherry 0 Posted November 17, 2010 Report Share Posted November 17, 2010 I would say it sounds like an ECU problem. Get it sent off, bet they cure the issue (H) Link to post Share on other sites
mk3_matt 21 Posted November 19, 2010 Author Report Share Posted November 19, 2010 rite the vr runs ok now just got a problem trying 2 bleed the water system is there a special way 2 do it on these Link to post Share on other sites
p0u1 14 Posted November 24, 2010 Report Share Posted November 24, 2010 fill it to the max level, turn the motor on and let it run without the water cap on, carry on toping it up as it falls all the way till it stops falling. Link to post Share on other sites
