Just collected my winter car - B5 Estate 20v Non turbo
Only problem is the central locking does not work !
I can see there is ment to be a red led on the door pins however that isnt flashing either !
My first port of call in the morining is a fuse box but wondered if its a common problem or has anyone else had any issues like this
PLEASE HELP
The central locking is now working after 2 hours sorting wires out due to water damage.
However with my golf the central locking works with the key and also if the window opens when u lock the car and hold the key the window shuts !
Is this the same with a passat ?
If so what do i need to change to make it work ??
