probert993 0 Posted October 3, 2010 Report Share Posted October 3, 2010 does anyone know whether the coil pack on the mk4 v6 4 motion is the same as my golf mk3 vr6's??after a good used one cant afford new , and wondered if they were same would have better chance of gettin good used one!anyone with info would be greatcheers Link to post Share on other sites
CALICO 130 Posted October 3, 2010 Report Share Posted October 3, 2010 i thought the mk4 ones were seperate pack per plug Link to post Share on other sites
UnitedMotorsport 55 Posted October 3, 2010 Report Share Posted October 3, 2010 The coil pack on the earlier 4motions (AUE and AQP) is the same - All you need to do is replace the amplifier section of it with your 12v one. The actual coils are the same. Link to post Share on other sites
UnitedMotorsport 55 Posted October 3, 2010 Report Share Posted October 3, 2010 i thought the mk4 ones were seperate pack per plug Earlier engines: AUE and AQP use a single coil pack like the 12vThe later BDE engine uses individual coil packs Link to post Share on other sites
probert993 0 Posted October 3, 2010 Author Report Share Posted October 3, 2010 what is amp section?? prob i have at mo is everytime it rains engine runs terrrible back fires the lot, sprayed water over pack other night in dark sparks everywere from outside pack so defo pack hey?? it did have crack in it sealed it but no improvement!! Link to post Share on other sites
UnitedMotorsport 55 Posted October 3, 2010 Report Share Posted October 3, 2010 The coil 'pack" is in two sectionsThe coils and the amplifierRemove your coil pack, undo the 2 screws on the back of it. On top there is a plastic cover, covering 5 terminals. Undo these terminals (8mm nuts) and slide the rear section of the coil pack off. Link to post Share on other sites
kebster 0 Posted October 3, 2010 Report Share Posted October 3, 2010 try covering it with high temp silicone it might have an affect Link to post Share on other sites
probert993 0 Posted October 3, 2010 Author Report Share Posted October 3, 2010 might try doing the seal bit properly first then didnt know that it split in two, any ideas were i can get high temp sealant from or whats good to use?? Link to post Share on other sites
kebster 0 Posted October 3, 2010 Report Share Posted October 3, 2010 From any plumbers merchants i use it for flues. Its called plumb a flue Link to post Share on other sites
probert993 0 Posted October 3, 2010 Author Report Share Posted October 3, 2010 thanks will have to have ago!! Link to post Share on other sites
UnitedMotorsport 55 Posted October 3, 2010 Report Share Posted October 3, 2010 In the right hand side of the picture below, you can see the 2 halfs. Link to post Share on other sites
probert993 0 Posted October 3, 2010 Author Report Share Posted October 3, 2010 were do i put sealant then once split etc Link to post Share on other sites
probert993 0 Posted October 3, 2010 Author Report Share Posted October 3, 2010 does anyone know if i can seal with tigerseal need to know if it is waterproof heat proof etc cheers got some in shed hence question Link to post Share on other sites
kebster 0 Posted October 3, 2010 Report Share Posted October 3, 2010 Not sure mate but sealing might not cure it u may have to get a new coil pack its just a suggestion Link to post Share on other sites
