sub frame doing my head in
im having issues with my sub frame and the bolts that hold it in, i thought id solved this but its back again, basically when i give the car some pasty or if it spins in the wet its makes an almighty crack sound and then again on braking, its been put down to the drivers side bolt which holds the frame on through the wishbone bush having play in it, ive had it cut out new bolt in and somthing welded in but that last all of 2 months and now its back has anyone else had similar problems ? and managed to solve it
cheers
