probert993 0 Posted September 20, 2010 Report Share Posted September 20, 2010 found nail in each front tyre, not touched it pulled it etc no pressure being lost how worried should i be dont wanna lose tyre etc cos loads of tread left but dont want it to be dangerous? Any advice cheers Link to post Share on other sites
Ian_rogers 0 Posted September 20, 2010 Report Share Posted September 20, 2010 Get them repaired mate, as the nails get worn away they will eventually cause a flat, best to get it done at ur convienience than where ur out in the middle of nowhere Link to post Share on other sites
probert993 0 Posted September 20, 2010 Author Report Share Posted September 20, 2010 how much normally just as a guide? , they normally repairable then? there in middle not on side wall Link to post Share on other sites
spindat45 0 Posted September 20, 2010 Report Share Posted September 20, 2010 As long as they are about an inch from the outer edge of the tyre then they should be repairable. A decent tyre shop should be able to do the repair. I had two front tyres fitted and a puncture repaired on a rear tyre the other day and they charged me £25 cash. That was at a place I've been going to for years so I think I got a bit of discount. A puncture repair shouldn't cost much more than £15 with the valve and balancing per wheel.Kevin Link to post Share on other sites
rodney 17 Posted September 21, 2010 Report Share Posted September 21, 2010 as with all things do it as soon as you can... As you can appreciate these are the things that keep you in contact with the road. So always worth doing ASAP. As said repairs should be no problems as long as they're in the centre section as described by spindat... Link to post Share on other sites
