Climatronic question
problem i have is that the climatronic turns on every morning with a different temp/fan speed. Is there anyway of leaving it off. I dont really use this much so it bugs me when it turns on as soon as i turn the ignition on. Also It flashes with some random digits on the display.
Make sure you get it on VagCom first, pointless gassing it up if the codes come up with a different problem.
Also make sure the fault codes are cleared then run the car as it is with the fault and see what code it comes up with, old codes may still be logged and you dont want to be chasing a fault that isn't there.
