Flagbuggy 0 Posted August 9, 2010 Report Share Posted August 9, 2010 HI Guys up to what HP can I still use my std rods and when do I start using ARPRod bolts I have read some where that the std rods can handle 380Whp easy is this true??And the 2nd question is what after market Conrods do I then buy ?Thanks in advance Pierre Link to post Share on other sites
golfrabbit33 0 Posted August 9, 2010 Report Share Posted August 9, 2010 standard is fine til 500+ ft of torque, get them peened (strenghtened) ,not to expensive to have done. 380@ wheel is no problem. yes,use ARP`s. do compression test before you start anything, replace all wear n tear parts, Link to post Share on other sites
MaidenVR6 26 Posted August 9, 2010 Report Share Posted August 9, 2010 Like above. Did 2 years with 20 psi all day long on stock engine with 8.5:1 C2 headspacer. No engine issues, what so ever. C2 software. Link to post Share on other sites
matty.vrt 120 Posted August 10, 2010 Report Share Posted August 10, 2010 i put 450 whp through standrd rods and pistons no probs. Link to post Share on other sites
Flagbuggy 0 Posted August 10, 2010 Author Report Share Posted August 10, 2010 i put 450 whp through standrd rods and pistons no probs.Holy moly Are you using a head spacer for lowering compression or what is the trick ? also fuel mix must be good then Pierre Link to post Share on other sites
rodney 17 Posted August 10, 2010 Report Share Posted August 10, 2010 yes most use head spacers and yes the management is everything.. C2 do great maps and a lot of people are very happy with them... and the rolling road is a must to be honest.. to get everything running correctly... Link to post Share on other sites
jims13 6 Posted August 11, 2010 Report Share Posted August 11, 2010 power as per sig, only got ARP HEADBOLTS, c2 uk management + supporting mods , only running a spacer plate . now at 185000 miles on orig engine Link to post Share on other sites
matty.vrt 120 Posted August 11, 2010 Report Share Posted August 11, 2010 I also use head spacer and c2 management but i use standard head bolts. Link to post Share on other sites
Flagbuggy 0 Posted August 11, 2010 Author Report Share Posted August 11, 2010 Hi thanks guys Any details for C2 When I click on the C2 of everyone I get directed to a page all I can make out C2 Motorsport UK but no contact details Help want to find out about a spacer plate When using a spacer plate do you use a head gasket either side or no head gasket just the spacer plate Pierre Link to post Share on other sites
golfrabbit33 0 Posted August 11, 2010 Report Share Posted August 11, 2010 sales@c2motorsports.co.uk Link to post Share on other sites
Flagbuggy 0 Posted August 11, 2010 Author Report Share Posted August 11, 2010 Hoi Thanks Sent them a mail Link to post Share on other sites
