dman78 1 Posted August 4, 2010 Report Share Posted August 4, 2010 as above i just need to know if i need to remove the wheel and get underneath to change the top mounts,or is it all done from the top,cheers Link to post Share on other sites
dman78 1 Posted August 4, 2010 Author Report Share Posted August 4, 2010 ??? Link to post Share on other sites
russj249 2 Posted August 4, 2010 Report Share Posted August 4, 2010 you'll need to drop the suspension leg off to do it really. not a hard job at all, top mount nut can be a bugger to undo without damper turning, but will come off with an air gun, 2 x 18mm bolts on hub and you're pretty much done. will need tracking and camber doing unless you mark exactly where the 18mm bolts go Link to post Share on other sites
Nex 17 Posted August 4, 2010 Report Share Posted August 4, 2010 ^^^What he said Do Mk3's not have the allen key hole in the top of the strut to stop it spinning when you undo the nut?? Link to post Share on other sites
ashmk3 0 Posted August 4, 2010 Report Share Posted August 4, 2010 Mine does well my coilovers do and it's the very popular 7mm Allen on mine. Link to post Share on other sites
DanH 1 Posted August 4, 2010 Report Share Posted August 4, 2010 yea standard shocks have that allen key to stop it spinning too Link to post Share on other sites
russj249 2 Posted August 4, 2010 Report Share Posted August 4, 2010 yep they do have an allen key in the top, but if it's anything like mine, with normal hand tools it'll just scrap the allen key or shock. There was so much lock-tite from the factory on the top bolt I couldn't shift it.I took mine to work and a good air gun will get it off it seconds without having to faff around with the allen key bits. Link to post Share on other sites
bungy 2 Posted August 4, 2010 Report Share Posted August 4, 2010 I undo them with the weight of the car on it's wheels and then use an airgun which works really well. Then when both are off jack the car up and place on stands. Link to post Share on other sites
