carl7777 0 Posted July 11, 2010 Report Share Posted July 11, 2010 hi guys,thanks for your advice last week about buying a vr6...i got it yesterday and love it so much..i did panic when the temp warning light came on but searched the site and found its a common problem,i give her a good clean and driven it about 100 miles and all seems well...im having problems with the cd player,when i turn the igntion on or off the head unit lights up and sometimes plays....im thinking i have a prob between the head unit and ignition switch,does anyone know if i can thread a wire to the live termenal on the battery to the head unit to check this out cheers,arl Link to post Share on other sites
b road blaster 0 Posted July 11, 2010 Report Share Posted July 11, 2010 glad your injoying it mate Link to post Share on other sites
Dazdub 0 Posted July 11, 2010 Report Share Posted July 11, 2010 No advice on head unit im afraid but congrats on getting your VR mate. Let the good times roll Link to post Share on other sites
b road blaster 0 Posted July 11, 2010 Report Share Posted July 11, 2010 well on the head unit if you pull it out the should be a perm live and switched live so just conect them both to the perm live and see if that works just means you will have to turn the unit on and off each time you use it Link to post Share on other sites
bungy 2 Posted July 11, 2010 Report Share Posted July 11, 2010 Congratulations on your new purchase. Link to post Share on other sites
cornishvr6 52 Posted July 11, 2010 Report Share Posted July 11, 2010 welcome mate, where in cornwall are you located? Link to post Share on other sites
carl7777 0 Posted July 11, 2010 Author Report Share Posted July 11, 2010 thanks guys...still no luck with the head unit though...it plays with ignition switched on but goes off when car is started Link to post Share on other sites
carl7777 0 Posted July 11, 2010 Author Report Share Posted July 11, 2010 launceston Link to post Share on other sites
b road blaster 0 Posted July 11, 2010 Report Share Posted July 11, 2010 sounds like a loose wire somwhere then mate Link to post Share on other sites
carl7777 0 Posted July 11, 2010 Author Report Share Posted July 11, 2010 ill try new block connectors.....think my mate has a jvc head unit so may try conecting that too...im sure i can live wih just the sound of the v6 purring and growling till i sort it Link to post Share on other sites
terrorste 0 Posted July 13, 2010 Report Share Posted July 13, 2010 I saw a Raddo VR6 for sale in St Ives on saturday, i cant beleve how many vr's I saw over the weekend! Link to post Share on other sites
carl7777 0 Posted July 13, 2010 Author Report Share Posted July 13, 2010 about how many were made ? Link to post Share on other sites
vr6stormt 0 Posted July 13, 2010 Report Share Posted July 13, 2010 apparently not enough to substitute making a proper uk spec haynes manual lol Link to post Share on other sites
scottg 0 Posted July 19, 2010 Report Share Posted July 19, 2010 i had the same problem with my head unit i just wired the stereo as above have the stereo permantly live so i have to either remover the face slightly or switch it off ie removing the ignition, works fine for me.was told they suffer with bad ignition switches or somthing was a free fix so worked fine for me Link to post Share on other sites
carl7777 0 Posted July 19, 2010 Author Report Share Posted July 19, 2010 i wired it direct and just slighty have the face off to turn it off..works fine,....i did wonder as in the boot of the car was an ignition barrel/switch,key and door handles locks etc,i need to find out it its good or not ! Link to post Share on other sites
