daxmatt 0 Posted July 7, 2010 Report Share Posted July 7, 2010 Hello all, im after some help with this one, sorry if its been done to death but couldnt find it, I have just bought a 93 aaa passat vr6 wagon with auto box code cff, the box is knackered and given the boxes are nearly 2 grand I dont want to repair the auto, I want to do a manual conversion and im well aware of what it needs to be done, the plan is buy a mk3 vr6 golf and strip all the bits I need the idea being I have all parts to hand on a full car, but I want to make sure that the box will mate up, so bassically will any vr box fit any vr engine and what is the diffence between codes as even though I would infact have a spare engine I would like to use the original engine the car came with, given how rare the car is its not really an option to just buy a manual lolcheers matt Link to post Share on other sites
daxmatt 0 Posted July 22, 2010 Author Report Share Posted July 22, 2010 141 views and no reply some one must know the difference in the boxes Link to post Share on other sites
Rikki 2 Posted July 22, 2010 Report Share Posted July 22, 2010 Any vr6 specific box will fit the engine physically. Slighly different ratios is the difference. Whether it will fit straight in a Passat i dont know!! Link to post Share on other sites
DanH 1 Posted July 22, 2010 Report Share Posted July 22, 2010 yea should do....known of donar passats being used for mk2 swaps etc so should all jus bolt straight up. i thought all the mk3 and 'rado boxes the same ratio, bellhousing, mounts etc? sure jus the selector and code that differs on the 'rados. reckon if u comfortable with doing the full auto to manual swap then u'll easily sort any probs along the way! gd luck! Link to post Share on other sites
Flagbuggy 0 Posted August 9, 2010 Report Share Posted August 9, 2010 Hi I am a noob but have a S4 audi and a 2003 2Lturbo Passat and the new beetle Vr6T so by comparring them all The golf box will not work in the Passat as the passat box bolt to the "BACK" of the Vr motor with the CV`s going out on the sides 90Deg to the flywheel of the VR Where the Golf box the CV`s sit parrallel to the flywheel of the Vr SO Sorry mate that one I dont think will work As mentioned rather be on the lookout for the manual Passat box but only the VR one as the bolt patern on 4cyl and VR are different Link to post Share on other sites
daxmatt 0 Posted August 10, 2010 Author Report Share Posted August 10, 2010 Cheers chaps, just getting all the rest of the info together for some finishing then starting the job, im getting a full vr and stripping all the bits I need of that, maybe even take the engine at the same time now lol,cheers for looking flagbuggy but you passat is much newer than mine and the engines are mounted at a completly different angle to my vr, on mine its mounted exactly the same as mk3 vr golf, wouldnt mind seein a pic of the s4 though allways liked them, I had a v8 s6 avant for a few years, great cars crap on fuel lolcheers matt Link to post Share on other sites
daxmatt 0 Posted August 10, 2010 Author Report Share Posted August 10, 2010 Cheers chaps, just getting all the rest of the info together for some finishing then starting the job, im getting a full vr and stripping all the bits I need of that, maybe even take the engine at the same time now lol,cheers for looking flagbuggy but your passat is much newer than mine and the engines are mounted at a completly different angle to my vr, on mine its mounted exactly the same as mk3 vr golf, wouldnt mind seein a pic of the s4 though allways liked them, I had a v8 s6 avant for a few years, great cars crap on fuel lolcheers matt Link to post Share on other sites
