CALICO 130 Posted June 27, 2010 Report Share Posted June 27, 2010 Can you use the R32 clutch and flywheel or do you neec the VR one he will be using the vr box Link to post Share on other sites
craggsy 91 Posted June 27, 2010 Report Share Posted June 27, 2010 clutch and flywheel have to match the gearbox I beleive Roger Link to post Share on other sites
UnitedMotorsport 55 Posted June 27, 2010 Report Share Posted June 27, 2010 Use the clutch and flywheel that belongs to the gearbox. Link to post Share on other sites
CALICO 130 Posted June 27, 2010 Author Report Share Posted June 27, 2010 chears peeps thats what i thought just wanted confirmation Link to post Share on other sites
CALICO 130 Posted June 27, 2010 Author Report Share Posted June 27, 2010 C2 how much would it cost to remove immobiliser from an R32 ECU Link to post Share on other sites
UnitedMotorsport 55 Posted June 27, 2010 Report Share Posted June 27, 2010 You will more than liley need more than the immo turning off. When doing engine conversions, there are some systems deletes that could be required.Some of these systems are: Secondary Air InjectionPost cat. Lambda probesWe can do the Immo defeat and any other systems delete for £100.One of ours guys has a R32 in a MK2 Golf, it runs perfect with NO fault codes. Link to post Share on other sites
