Changing the oil yesturday and noticed theres a few scrapes on the sump from where its been catching. The sump plug is even worse.
Done a bit of research and the R32 seems a shallower sump but heard if it hits it will shatter unlike the VR sump which is stronger.
Where can I get a strong shallow sump? Im know im going ot need a new oil pump and pick up (R32?)
I dont see the point in running a sump guard becasue it only reduced clearance. Unles I get a shallow sump and raise the engine then fit 1 or a skid plate then the clearance might be the same but it wont be worse.
I have thought about engine spacers, but how big do the spacers need to be? Does it add extra stress when raising he engine on other parts?
Thanks
