ashmk3 0 Posted June 18, 2010 Report Share Posted June 18, 2010 Right tonight a friend came round to test my car after my conversion from gti to vr6 (mk3) the lead is getting power because the led light is on but it dosent want to scan, we have taken the radio out, changed the clocks from vr6 to gti back to vr6 still nothing. Does anyone have a picture of the wiring or any ideas what could be causing this. Link to post Share on other sites
squid1 0 Posted June 18, 2010 Report Share Posted June 18, 2010 have u linked the k line up Link to post Share on other sites
ashmk3 0 Posted June 18, 2010 Author Report Share Posted June 18, 2010 K line ? What's this it's obd2 if that helps Link to post Share on other sites
squid1 0 Posted June 18, 2010 Report Share Posted June 18, 2010 it the wire tht links the ecu to the port for vagcom... does it come up linking error Link to post Share on other sites
ashmk3 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 I'm not 100% but I'm sure it was something along those lines yes. What dose this wire look like and where does it run? Link to post Share on other sites
squid1 0 Posted June 19, 2010 Report Share Posted June 19, 2010 http://mk2vr6.com/board/viewtopic.php?f=12&t=7831 have a read at tht its all in there Link to post Share on other sites
ashmk3 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 Hmm thanks for this I think I need to tap a wire into the ground. A quick question which will help is if I unplug the cam sensor when the engine is running what should happen? Link to post Share on other sites
squid1 0 Posted June 19, 2010 Report Share Posted June 19, 2010 if im right i think it should cut out but not to sure as it needs tht and the crank to do the spark i think im not to sure! the k line needs to b cut and need to the speedo under the dash it where it plugs in that where mind did but mine was a 1992 golf so obd1 with obd2 engine! i used tht site for all of my wiring so if u go through it, it should help well i hope it does Link to post Share on other sites
ashmk3 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 Yh from what read I need to wire the kline into the brown ground lead in the fuse box. Well if my cam sensor isn't working that would explain underpowered and bad fuel burn as the spark is weaker so it's running rich which would explain some o the smoke I get. Thanks alot for the info. Link to post Share on other sites
squid1 0 Posted June 19, 2010 Report Share Posted June 19, 2010 tht also could b the ht leads aswel! Link to post Share on other sites
ashmk3 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 Leads and plugs are new and coil pack is also I I've changed the maf which to make sure was fine I put it on with the arrow facing forwards opposite the airflow direction and it hardly ran. So I unplaugged the cam sensor and nothing happened unplugged the blue temp sensor and idle raised up so that's working. Link to post Share on other sites
squid1 0 Posted June 19, 2010 Report Share Posted June 19, 2010 try changing the cam sensor then fella Link to post Share on other sites
CALICO 130 Posted June 19, 2010 Report Share Posted June 19, 2010 putting the maf on the wrong way round tends to knacker them the arrow should face towards the throttle body Link to post Share on other sites
ashmk3 0 Posted June 19, 2010 Author Report Share Posted June 19, 2010 Yh I have brought one of a fellow vr6oc member is there anyother way of testig the maf? Link to post Share on other sites
