yakuza racer 16 Posted June 17, 2010 Report Share Posted June 17, 2010 ok, so i plug in my monthly VAG com test, and pick up a crank sensor error code.. my car still drives normally, so what is the symptoms of a buggered crank sensor??? Link to post Share on other sites
FishWick 21 Posted June 17, 2010 Report Share Posted June 17, 2010 OBD1 or OBD2? OBD1 hasn't been programmed to ignore a crank sensor issue when the engine isn't running, but OBD2 has.Symptoms = No fuel and no spark. When they are on the way out, they can cause very lengthy starting, or no starting at all until it's cooled down. Link to post Share on other sites
T0NYVR6 2 Posted June 17, 2010 Report Share Posted June 17, 2010 Where is the Crank sensor located? I only ask as my VR takes quite a few turns before it will start up! Link to post Share on other sites
vr6stormt 0 Posted June 17, 2010 Report Share Posted June 17, 2010 above the coil pack... Link to post Share on other sites
Dave Lea 4 Posted June 17, 2010 Report Share Posted June 17, 2010 below the oil cooler ..cam sensor is above the coil pack Link to post Share on other sites
yakuza racer 16 Posted June 18, 2010 Author Report Share Posted June 18, 2010 OBD1 and it seems fine, starts up first time.... drives normal, etc.. so would it be suggest i change it since it's giving me an error code or just leave it be? Link to post Share on other sites
FishWick 21 Posted June 18, 2010 Report Share Posted June 18, 2010 If it starts and drives normal, it's not the crank sensor.As I said, if you scan OBD1 with the engine off, you will get a crank error because the engine isn't turning. OBD2 was programmed to ignore it. OBD1 wasn't. Link to post Share on other sites
