Sunroof not closing with Scorpion TC Alarm
Hi can anyone help?
My highline has a Scorpion total closure alarm fitted, which until a few days ago use to close all the windows and sunroof when locking the car with one press as it should. Now the windows still close but the sunroof remains open!?...any ideas?..just a glitch/failure in the control unit?..last time i check the wiring it was fine?
Help!...a bit frustrating!
cheers
have you double checked all the windows close with the alarm if one window dosnt close it wont close the sunroof
i found thiss when i forgot to reconnect one of my windows when installing stereo
Hi
might be the answer...sort of!...i have a five door and all windows work but when i open as normal, but when using the alarm fob all shut except one rear and the sunroof?!
I know that some time ago when the sunroof was closing with the alarm, that same back window didn't work, motor 'appeared' to be jammed...just made a weak buzzing sound when window button was pressed which i put down to a faulty motor, bought motor, about to replace it and then rear window came back to life!...but now this problem has occured. Could it be an intermitently working rear window motor causing the problem?, and should i just change it anyway?
all help greatly appreciated before i strip the rear door down!
not too difficult to change just the motor but id deffo try that
IT WORKED!!
changing the motor cured the problem..also my loom had chafed against the door which i guess had effected the original motors operation?..even though it still worked perhaps something else had gone internally?
anyway real happy
cheers!
Sounds like a silly thing but check the earth cable. As far as I know all the earth cable is brown. My drivers window acted like the motor went so I changed the motor and regulator. Auto electrician, 5 mins and £20 turned out to be just 1 strand of copper connected in the earth cable. Located in the rubber boot between the car chassis and the door.
