vr6stormt 0 Posted May 25, 2010 Report Share Posted May 25, 2010 as above cant undo the top adjuster ring bottom one was ok tried a couple of things even heat is there a trick to this or does anyone know were i can get replacements,,then i can cut the old ones off they are fk sports thanks Link to post Share on other sites
legvw 0 Posted May 25, 2010 Report Share Posted May 25, 2010 Wd40, a vice, and a big set of stilsons mate! Link to post Share on other sites
vr6stormt 0 Posted May 25, 2010 Author Report Share Posted May 25, 2010 yep i thought of that but my stilsons only open an " lol its doing my head in tried wd40 cleaned the threads which are good cond anyway it just dont want to move Link to post Share on other sites
legvw 0 Posted May 25, 2010 Report Share Posted May 25, 2010 There isn't a grub screw in the side of the adjuster is there? I know some kw's use them, and they're tiny, could have missed it? Link to post Share on other sites
vr6stormt 0 Posted May 25, 2010 Author Report Share Posted May 25, 2010 nope no grubbys just tight. was a bit concerned about using the heat though incase it went bang lol Link to post Share on other sites
Ben Seabrook 4 Posted May 25, 2010 Report Share Posted May 25, 2010 nah will be fine mate, stick the coily in a vice heat the ring up and hit it with a big hammer and a screwdriver Link to post Share on other sites
Sheeldzy 1 Posted May 25, 2010 Report Share Posted May 25, 2010 Punch and hammer FTW. Do take care with the heat, warm and cool them gradually as the alloy is loads more brittle than steel. Should be fine though. Link to post Share on other sites
thegoth 5 Posted May 25, 2010 Report Share Posted May 25, 2010 plusgas, far more effective than WD40 Link to post Share on other sites
gavinvr6 0 Posted May 25, 2010 Report Share Posted May 25, 2010 is the spring loose when the shock is on full droop? if not try compressing the spring slightly with the shock on full drop to take pressure off the ring then tap it round with a mallet and chisel/punch. otherwise just keep it lubed up and keep tapping it with a soft face mallet like a copper on to shock it. a club hammer may bend something Link to post Share on other sites
Ian_rogers 0 Posted May 25, 2010 Report Share Posted May 25, 2010 I used a really big hammer and a file Link to post Share on other sites
