gavinvr6 0 Posted May 12, 2010 Report Share Posted May 12, 2010 folks my v failed it's mot on welding for inner rear arch and emmision's way to high, it was 0.6 when limit is 0.2.i got someone to do the welding for me but need advice on the emmision's.i've got a bottle of 10k boost to clean out the inlet and combustion chambers and some fuel system/injector treatment to be safe on the fuelling side of things. and will be replacing the air filter as mine is in a dreadfull state after being located behind front bumper and getting wet and rusting badly.is there anthing else i can do to try and get my emmision's down? Link to post Share on other sites
VR6Pete 1,455 Posted May 12, 2010 Report Share Posted May 12, 2010 have you had it on the VAG-COM - check lambda, possibly you may need a new CAT - how many miles has it covered?My 3 year old punto failed on emmisions at the MOT, passed in the end, I had to give it a good thrash to get everything hot hot... Link to post Share on other sites
gavinvr6 0 Posted May 12, 2010 Author Report Share Posted May 12, 2010 not had it on vag com as no mot or tax at present so cant get no-where.have run a fault code reader over it and it's chucking up isv-engine speed sensor-earth supply voltage (but dont say what for.the cat and lambda have both seen less than 5k since i replaced em both after burning out everything racing a shaguar im gunna pop a load of chemical's into it and rev the nut's out for an hour or so to get the temp up and the crap out Link to post Share on other sites
993turbo 0 Posted May 12, 2010 Report Share Posted May 12, 2010 I just failed the emisions as well... I had 0,9 CO.... Let me know what you do and figure out! Mine is all fine on the VAGCOM Link to post Share on other sites
gavinvr6 0 Posted May 12, 2010 Author Report Share Posted May 12, 2010 well i've been advised new filter and a cleaner so using 10k for the inlet and wynn's fuel cleaner for the fuel system. hopefully that should bring it down a chunk Link to post Share on other sites
