Antihero1981 8 Posted April 24, 2010 Report Share Posted April 24, 2010 Hi guys , took the inlet off to get powdercoated and also changed the spark plugs , put everthing back together but now i cant get it to run correctly , i think i put all the leads back correctly as marked on the leads and coil pack , but when i put my foot down it sounds muffled and like a gobbling sound...never did it before so got to be something i done in the processi presume the coilpack number line up with the lead numbers?thanks vortech v9 obd2 vento Link to post Share on other sites
matty.vrt 120 Posted April 24, 2010 Report Share Posted April 24, 2010 yeh they do. make shure they are all pushed right on and check the new plugs are gapped correctly.i run .024 Link to post Share on other sites
Antihero1981 8 Posted April 24, 2010 Author Report Share Posted April 24, 2010 was told they should be set up correctly straight out the box , did not gap them.....will double check the leads + coilpack Link to post Share on other sites
legvw 0 Posted April 24, 2010 Report Share Posted April 24, 2010 Did you plug everything back on to the manifold, i.e the air intake temp sensor/fpr vac line? Link to post Share on other sites
Antihero1981 8 Posted April 24, 2010 Author Report Share Posted April 24, 2010 yeah i double checked that , its wierd as up to about 3k revs its ok , only when i call for more power above 3k it battles , idle is okmight take leads off and try again Link to post Share on other sites
