mikey 0 Posted April 17, 2010 Report Share Posted April 17, 2010 hi guys does any one know if the 4wd system is a 50 50 split the reason being is we have had the idea of building a rwd mk 3 by removeing the front driveshafts and leaving the rest wasnt sure if all the power woulg go to the backs any suggestions greatly appreciated Link to post Share on other sites
b road blaster 0 Posted April 17, 2010 Report Share Posted April 17, 2010 no mate its not 50/50 the way the haldex works means it varies the split as diff grip is required Link to post Share on other sites
bungy 2 Posted April 17, 2010 Report Share Posted April 17, 2010 As Russ says above. Haldex VW's are front wheel drive with a drive shaft running to the rear, through a clutch before the rear differential. Here is a graphic of how they work. Link to post Share on other sites
mikey 0 Posted April 26, 2010 Author Report Share Posted April 26, 2010 thats great guys thanks for the info but what about the earler kit is it the syncro ? Any other ideas on how it could be done? Link to post Share on other sites
legvw 0 Posted April 27, 2010 Report Share Posted April 27, 2010 Syncro is basically the same as haldex, once the fronts 'spin' power is used from the prop to power rears to minimise the fronts spinning. Syncros use a viscous coupling, rather than a wet clutch (haldex). Nether can be used as rwd only, it just won't work. Link to post Share on other sites
