power steering pump tapping... now ok
Not that I was aware of, have you tried listen to the tapping with the ol' screwdriver to the ear trick?? or obtain an old stethescope and listen to the noise...
Does the tapping rise with the revs or is it constant? where does the sound originate, top of the engine, side, front or rear? what kinda tapping do you hear? loud, hard knocking or a more gentle tapping, which would you say it was?
If you can answer these, then it may guide us in the right direction, or someone may have had the same problem.
Good Luck, let us know how you get on.
Regards
28v6r
[ Edited Sun Feb 22 2004, 02:26PM ]
my vr is making a dry tappet sound form low down ,can't really hear from top but can hear it from drivers side wheel has stopped now belt removed, pump off ,but can not make pump make noise off car (car done 94 k) tapping sound speed link to engine speed )
  • 5 years later...
