Jess_smif124 0 Posted March 24, 2010 Report Share Posted March 24, 2010 My Car started makin a whining noise from the engine. i havent got a clue what it is!! someone said it might be the alternator! anyone else got any ideas?? Link to post Share on other sites
VR6Pete 1,455 Posted March 24, 2010 Report Share Posted March 24, 2010 hi jess, does it only happen when cold, or all the time? Pop open the bonnet, and listen out where your auxiliery belt is - could be alternator, or simply the pulley bearing....does the whining noise increase when the engine engine rev's, or is it a constant noise? Link to post Share on other sites
VR6Nat 9 Posted March 24, 2010 Report Share Posted March 24, 2010 listen to the engine on tick over... is there any rattling coming from the left hand side of the block next to the airbox?? does it get worse the faster you go?? does it happen when you have your foot on the clutch and are rolling?? Link to post Share on other sites
VR6Nat 9 Posted March 24, 2010 Report Share Posted March 24, 2010 lol... pretty much the same reply pete!! not bad!! hahaha... Link to post Share on other sites
Jess_smif124 0 Posted March 24, 2010 Author Report Share Posted March 24, 2010 lol! wel i changed the auxiliery tensioner and since then it started squeekin a bit but it whinining when i turn it on when its cold but when its warmed up its sound like a grasshopper lol! il open my bonnet and have a proper listen when i get home from work. it whining when im driving but its makin the grasshopper noise when its ticking over when its warm or if im rolling (im use sooo many technical words lol) Link to post Share on other sites
VR6Nat 9 Posted March 24, 2010 Report Share Posted March 24, 2010 it could be the bearings in your tensioner pulley are shot... mine were, which causes it to whine when driving and it sounds like a nasty grinding noise when on tick over... if its not that it could be your water pump or even worse it could be your gearbox, but if its happened since you put the tensioner on then its more than likely that.. was it a new part you used or one off another car?? Link to post Share on other sites
Jess_smif124 0 Posted March 24, 2010 Author Report Share Posted March 24, 2010 it was a new part. just out of interest...... r u a girl? lol Link to post Share on other sites
VR6Nat 9 Posted March 24, 2010 Report Share Posted March 24, 2010 ahh well it should be ok then... weird... have a listen about on tick over later, but could be the water pump... and yeah, im a girl.. lol Link to post Share on other sites
Jess_smif124 0 Posted March 24, 2010 Author Report Share Posted March 24, 2010 u no alot 4 a girl lol its lost it power now tho Link to post Share on other sites
legvw 0 Posted March 24, 2010 Report Share Posted March 24, 2010 Can you take the pressure off of the belt again (as if you were changing it) and spin the alternator. Listen to the noise it makes, feel for rumble etc, do that on the water pump too. Also check for bearing play by pulling the pulleys up down left right etc. Link to post Share on other sites
Bigjobbo 0 Posted March 24, 2010 Report Share Posted March 24, 2010 Do you know which side it is? I is thinking clutch and bearing. Link to post Share on other sites
Jess_smif124 0 Posted March 24, 2010 Author Report Share Posted March 24, 2010 its the offside its coming from?? Link to post Share on other sites
legvw 0 Posted March 24, 2010 Report Share Posted March 24, 2010 I think this is linked to your loss of power mate, but try what i said above and get it on vagcom like ben said. Link to post Share on other sites
VR6Nat 9 Posted March 25, 2010 Report Share Posted March 25, 2010 u no alot 4 a girl lol its lost it power now tho haha, it comes from spending too much time on here... lol. but thanks, and i have replied in your other thread re the power loss... Link to post Share on other sites
