Polyurethane Bushes!! (UK source??)
Hi, me mounts r s****d and the only place i can seem to find bush kits from is BFI which is US and dont ship overseas?? USRT DO ship BFI bushes to uk but ur payin like £50 for the privalige!!
ANYONE HELP with UK suppliers that dont bum u on prices for Poly mounts?!?!
Cheers:S
the gti ones are identical mate, they fit right in. The lower arms, arb and rear shock tops must be the same, the part numbers for gti and vr6 stuff is the same on most of the suspension bits as far as i can see.
The vr6 ones are not better or different when it comes to the bushes, mounts and arms, only the spring and damper rates are different due to the increased engine weight, and the front strut top cushion mounts are beefier for the same reason. If your getting axle, wishbone and arb mounts just get a gti set, ask awsome or ebay seller, they will tell u the same ;)
hahah there seems to be some confusion here.... im not after the suspension/arm bushes and after engine mounts!! i was lookin at the BFI .5 poly kit to replace the existing rubbers within the mounts, save payin £140 for ONE front VF uprated poly mount.
