bungy 2 Posted February 26, 2010 Report Share Posted February 26, 2010 I'm trying to collect all the information together for the mk4 4 motion service items. Quantity, grade and eventually "how to's" for all the items required. I could do with some help to fill the gaps and get it together for future reference.Service itemsS numbers are superseded partsSpark plugs - Bosch FR7HPP22, NGK's PZFR5D-11*Coolant - 3 bottles G12 9.2 ltrs total *Engine oil - recommended annual - SZGB115QLB00511 -5ltr-*Engine oil filter - VW 071 115 562 A *Sump plug - N 90813201 - SN90813202 *Air filter - VW 1J0 129 620 *Pollen filter - 1J0-819-644*Fuel Filter - VW 1J0 201 511 A * Gearbox oil - 75/80w 2.6 ltr*Rear diff oil 1.1ltr*Front diff oil - ? *Haldex oil - G 055 175 A1 275 ml*Haldex filter - 02D 525 558A*Haldex tool - T10066 * Power steering fluid - 0.7-0.9 - VW G00200*Brake fluid, Clutch fluid - Dot 4/5 1ltr*Top mounts - 1J0412331C*Top mount bearing - 1J0412249*Air-con "O" seals - S7H0820898 & S8E0260749*Manifold stud N0445203*Head gasket 022103383FOEM & aftermarket part numbersvibra-technics competition RHS engine mount - VAG405M * vibra-technics competition LHS G'box mount - VAG408M S3 lower brace - 8N0 199 403 B (£12+vat) * riv/cap nut - N90 810 601 (80p+vat) x 2 * Screw/bolt - N10 417 601 (53p+vat) x2 * washers - N90 477 301 (42p+vat) x2 * S3 upper strut brace - 8L9805629A Sharan aerial - 7M0 035 849E * Sunglass holder - 1CO 857 465 Y20 (grey) -1CO 857 465 3PT (beige) * Toureg torch - Replaces cigarette lighter - 7L6 947 175 A * Front discs - Black Diamond - KBD971 312 mm * Front pads - Black Diamond - PP279 * Front valance(4mo) - 1J0 805 903 F B41 Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 i got haldex tool plus the oil from gsf oh and the fillter the rear diff oil i used was vw oil think it was a 70-80 but not 100% sure just ask gsf they know what you need it only takes 1.1 lt Link to post Share on other sites
bungy 2 Posted February 26, 2010 Author Report Share Posted February 26, 2010 I've already got the tool and done the Haldex service but can't find the numbers. Just thought it will be a good reference for later to log it all. Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 had a nightmare changeing the fillter undone it ok but trying to get it out was a PITA new one went in easy Link to post Share on other sites
legvw 0 Posted February 26, 2010 Report Share Posted February 26, 2010 Brake fluid and the clutch fluid are the same mate, they run off of the same reservoir. Think its probably dot 4, might be worth dot 5? A litre should do the lot. Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 bosch plugs number FR7HPP22black dimond front disc's part number KBD971 312 mmblack dimond front pad part number PP279 Link to post Share on other sites
bungy 2 Posted February 26, 2010 Author Report Share Posted February 26, 2010 Not too keen on Bosch plugs and you couldn't pay me to use them i'm afraid. Replaced mine with NGK platinums. Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 fair enough mate Link to post Share on other sites
bungy 2 Posted February 26, 2010 Author Report Share Posted February 26, 2010 All updated on the front page buddy Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 coolant vw G12or pentosin G001200upgraded brake/ cluch fluid motul RBF600NGK plugs part number PZFR5D-11haldex spanner vw part number T10066haldex filter vw part number 02D 525 558Ahaldex oil vw part number G 055 175 A1 275 ml Link to post Share on other sites
J5KE F 0 Posted February 26, 2010 Report Share Posted February 26, 2010 Not too keen on Bosch plugs and you couldn't pay me to use them i'm afraid. Replaced mine with NGK platinums.lol, I wouldn't use them on my work van let alone any other Vr! Love the list guys nice work and great idea Bungy Link to post Share on other sites
bungy 2 Posted February 26, 2010 Author Report Share Posted February 26, 2010 Between us we should get a nice long list of everything needed including quantities and part numbers. Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 have added haldex numbers on bottom of page 1 Link to post Share on other sites
b road blaster 0 Posted February 26, 2010 Report Share Posted February 26, 2010 pollen filter vw part number 1J0-819-644 Link to post Share on other sites
warby 0 Posted February 27, 2010 Report Share Posted February 27, 2010 Engine oil - 5.5l sump - 0.5l filter (filter should be filled before fitting, i put 5l in sump 0.5 in filter then run, stop and top up) 0w30 / 0w40 / 5w30 / 5w40 / 10w40 depending on area's temperature etc.Brake / Clutch - 1l - DOT4Coolant - 9.2l - I use any good 'pink' coolant / antifreezePower Steering - 0.7-0.9 - VW G00200 (mine only needs this cos i took the pipes off for motor out)Manual Transmission - 2.6l 75/80w Gear oilAll from Autodata and me Noggin:)See whats any use... Link to post Share on other sites
bungy 2 Posted February 27, 2010 Author Report Share Posted February 27, 2010 All updated on the front page. Keep'em coming fella's. Link to post Share on other sites
warby 0 Posted February 27, 2010 Report Share Posted February 27, 2010 Sump plug - ECS, Awesome GTI Awesome Product Code: EN-SUMP-ECS-MAG - It fitted my BDE motor, think its a good idea.Air Filter (panel type) - BMC BMC159/01 - K&N K/N33-2128 - Pipercross P/CPP1389 - Green GREP646531 - VW 1J0 129 620Oil Filter - K&N HP-7005 - VW 071 115 562 AFuel Filter - VW 1J0 201 511 A Link to post Share on other sites
bungy 2 Posted February 27, 2010 Author Report Share Posted February 27, 2010 Will have to run 2 lists. One with oem numbers and another with alternatives for aftermarket stuff. It's coming along nicely with all the help. Link to post Share on other sites
b road blaster 0 Posted February 27, 2010 Report Share Posted February 27, 2010 that would be a good idea mate as loads of non gen parts out there for sale i mean there must be 10 diffrent brake disc manufactrures out there same with pads Link to post Share on other sites
J5KE F 0 Posted February 27, 2010 Report Share Posted February 27, 2010 This could get confusing!! Nice result tho peeps!! Link to post Share on other sites
bungy 2 Posted February 27, 2010 Author Report Share Posted February 27, 2010 Trying to keep it usefull and clear... Link to post Share on other sites
b road blaster 0 Posted February 27, 2010 Report Share Posted February 27, 2010 i think you should also "sticky" the results so its nice and easy to find all the info Link to post Share on other sites
warby 0 Posted March 5, 2010 Report Share Posted March 5, 2010 N 90813201 Im lead to believe this is the genuine sump plug number. Link to post Share on other sites
bungy 2 Posted July 8, 2010 Author Report Share Posted July 8, 2010 Updated with top mount and bearing numbers Link to post Share on other sites
craggsy 91 Posted July 8, 2010 Report Share Posted July 8, 2010 Now how many of these are good with BFH engine? Link to post Share on other sites
