just been out to check on my front disc n pads as there about due for a new set and noticed something very strange about them. Ive got pagid fast road pads and brembo maxi grooved discs 288mm. The pads have worn down but as they have been doing so they have overlaped the disc so the pads worn now across about 90% of the pad face but its started to lip which is running on the inside of the disc where the wheel bolts attach to the hub. Not sure if the pads have moved or they where the wrong pads given to me from gsf when i bought the pads n discs. Any one got any ideas?
i dont know of any reason why the pads would overlap maybe get some more pads and see if its still like it if it is then check out the disks are the right ones?
because the pads are overlapping the disks they are not going to give even pressure on the disc face and you will end up with uneven wear on pads and discs...
not worried about that i bought the disc n pads together from gsf in leicester and need replacing now just done a year on them. To be fair they are the best brakes ive had on any car
wonder if the disc are right?
will get the part code in a min
i did check with my old disc's before removing and looked the same but not sure now as sumthings wrong
part code for disc
brembo 09.5570.75
gsf 60200
ive just looked on http://bremboaftermarket.com/En/Car_BremboMax/Catalogue_Search.aspx?SearchMode=Model&IsResult=True&SearchBrand=VOLKSWAGEN&SearchModel=Golf%20%28III%29&SearchIsFront=True
and looks like the disc's are 280mm
