obd1 distributer to obd2 coilpack
heading says it all, i am changing from a obd1 to a obd2 wiring loom and stuff for turbo reasons and my engine is a distributer cap and needs to be changed to a coilpack for it to run, can any of you petrol heads tell me how and what is needed for this thanking you for your help
  • 3 months later...
I'm in the process of turning my OBD1 Corrado VR6 to OBD2.
Parts needed;
Coilpack (well' date=' didnt need this as ive already got one!
OBD2 Throttle body
OBD2 Engine loom
Lambda sensor
MAF
Immobiliser stuff
OBD2 inlet manifold
when you do this please please can you do a write up,
I will also be doing mine but its going to get a bit tricky with the turbo install at the same time and some smoothing/spraying and hiding of looms
