davee 0 Posted January 19, 2010 Report Share Posted January 19, 2010 im going to do an oil change on the vr is the drain hole vw sign with 2 small bolts in it on the bottom also was going to use 80/90 castrol for this is this ok thaks guys! Link to post Share on other sites
cabrioman 6 Posted January 19, 2010 Report Share Posted January 19, 2010 the drain is the big allen key on the bottom of the diff and the fill is the same sized allen key on the front of the box ..... cant remember wot oil our gearboxes take thou .... Link to post Share on other sites
muttley 0 Posted February 12, 2010 Report Share Posted February 12, 2010 the drain is the big allen key on the bottom of the diff and the fill is the same sized allen key on the front of the box ..... cant remember wot oil our gearboxes take thou ....is there any photo's of these ? as i need to do mine soon Link to post Share on other sites
craggsy 91 Posted February 12, 2010 Report Share Posted February 12, 2010 Undo the fill plug first in case it doesnt undo and you've dumped old oil out Link to post Share on other sites
bungy 2 Posted February 12, 2010 Report Share Posted February 12, 2010 Undo the fill plug first in case it doesnt undo and you've dumped old oil outTop tip!If the fill undoes and the drain doesn't then use a vacuum pump to get the oil out. Link to post Share on other sites
craggsy 91 Posted February 12, 2010 Report Share Posted February 12, 2010 Some one told me that and it makes perfect sense....such a simple little thing that is so true Link to post Share on other sites
finny 0 Posted February 18, 2010 Report Share Posted February 18, 2010 Useful website I'm sure it has been posted beforehttp://www.brokevw.com/Lots of details and pictures to do with a VW gearbox in general Link to post Share on other sites
