MarksMintness 0 Posted January 14, 2010 Report Share Posted January 14, 2010 Hi guys,My VR seems to be easier to steer left than right does that make sense? It's always been like that since I got it a few months ago, I have since had new tyres on the front and tracking done but I have tried ignoring it but it's definitely there, something ain't right.There's no bad noises, no wobbling etc so I suspect the steering rack now.When the steering is wound on to the right it kicks back quite hard when released, not so much at all when it's wound on to the left, hardly any resistance at all. I think the steering wheel points to the left ever so slightly when you let go as well...Any ideas of what the problem could be and a possible solution?Cheers in advance Link to post Share on other sites
shail 0 Posted January 14, 2010 Report Share Posted January 14, 2010 Sounds like a steering rack issue. I has same symptoms, which got worse over time. Eventually had to have the rack replaced. Link to post Share on other sites
b19drg 0 Posted January 14, 2010 Report Share Posted January 14, 2010 As above had the same prolem , was the rack in the end. Link to post Share on other sites
MarksMintness 0 Posted January 15, 2010 Author Report Share Posted January 15, 2010 Cheers guys, thanks for the responses.Is this likely to be an expensive job? The sucker only has 62k miles on it so it's a bit gutting to say the least. I guess it's not about miles but lubrication and use etc...Cheers Link to post Share on other sites
