Hello, I've needed a new rad for a few weeks now because of a hole and I've had to top up the water every few days. Today I was running low on water and suddenly steam started coming in the car first from the speedo area then from the speaker. I opened up the window to let it out and found a garage. Filled up the rad again and when I pulled away there was no steam inside and I got all the way home with no problems. On the plus side the speedo glass is spotless after a steam clean but I'm worried.
Is it normal for the inside of the car to fill up with steam when the radiator is broken?
^ Thanks.
Does anyone know of a good way to test the heater matrix? Also how hard is it to change?
You will see signs if your matrix has gonemate,
Slowly the windscreen starts misting up...
Then floorpan becomes wet..
You can actually start smellin it in your car mate.. Also have you checked the Guttereing holes in the Engine bay are clear..?
No leaves etc, other wise you will get water in the car mate!!!
http://www.nwdubs.com
The only smell I've got is dog vomit. One of them plastered the back seats last week. I've vaxed it twice and I think it's not really drying out properly.
The steam only happened once, stopped after I put the water in. Pick up my new rad later on so that's all my spare time tomorrow taken up. Thanks for all the answers.
Picked up my rad from D&D. Nice VR6 in the carpark. Anyone from here?
New radiator fitted and now onto the matrix. I've started pulling the dash to pieces but there's only so much light in one day. I know I have to strip the dash totally but is it possible to leave in the steering wheel? I've removed two in my time and both times it ended badly with blood. Also, I'm trying to work out if it's matrix or pipes so it will have to go back together so I can go buy the parts. Any tips?
