terrorste 0 Posted January 2, 2010 Report Share Posted January 2, 2010 Mine is not feeling very well at the moment does anyone know of any good places around the midlands area to get it looked at or even a rebulid? Anyone on here do any work like this and fancy a challenge? might do the engine too! make it feel brand new. Link to post Share on other sites
cabrioman 6 Posted January 2, 2010 Report Share Posted January 2, 2010 wot the prob with the box ???? check condition of the oil mate a lot of auto box probs is due to crap oil .... Link to post Share on other sites
terrorste 0 Posted January 2, 2010 Author Report Share Posted January 2, 2010 I have been to a few places around here in Nottingham who wont even look at it maybe the lack of knowlege on vr's or auto boxes or even the mix of both. how would a slightly mechanicaly minded person check the oil and what should i look out for? Link to post Share on other sites
terrorste 0 Posted January 2, 2010 Author Report Share Posted January 2, 2010 Forgot to say the box is crazy sometimes. the kickdown doesn't work. when its cold and first drives it i have to rev it alot befor it moves and when i stop at first set of lights near my house and i pull off it goes to about 2.5k and thumps in to gear. Link to post Share on other sites
cabrioman 6 Posted January 2, 2010 Report Share Posted January 2, 2010 sounds like a lack of oil mate see if u can get any fault codes out of it if there is any that is .... get the trans nice and warm like after a long drive if possible keep engine running and put Netural or Park, and pull the dip stick out and check the level, that is if tha vr6 auto box has a dip stick im guessin it would do but never worked on one .... if u got a owners manual should tell u in there ... Link to post Share on other sites
terrorste 0 Posted January 2, 2010 Author Report Share Posted January 2, 2010 Not got the owners maunal but i cant see a dipstick only got one for the engine oil. i have also found out i have oil in my water. i want to get it all fixed so it runs like new! Grr Link to post Share on other sites
CALICO 130 Posted January 2, 2010 Report Share Posted January 2, 2010 auto box is sealed could be the gearbox oil cooler mixing water oil its on top of the gearbox i had mine serviced for £140 Link to post Share on other sites
terrorste 0 Posted January 3, 2010 Author Report Share Posted January 3, 2010 will have to look into servicing it then thanks guys Link to post Share on other sites
terrorste 0 Posted January 3, 2010 Author Report Share Posted January 3, 2010 auto box is sealed could be the gearbox oil cooler mixing water oil its on top of the gearbox i had mine serviced for £140Did you pay that at a auto box specialists or a normal garage? Link to post Share on other sites
leigh_f 0 Posted February 22, 2010 Report Share Posted February 22, 2010 did you ever get to the bottom of this? i have a similar problem. also where did you get box servied calico?thanks Link to post Share on other sites
terrorste 0 Posted February 22, 2010 Author Report Share Posted February 22, 2010 No its still a problem when cold, been told it could do with an oil change and also maybe replacing the heat excahange on the gearbox that might solve the issue. Link to post Share on other sites
leigh_f 0 Posted February 22, 2010 Report Share Posted February 22, 2010 cheers will look into getting these bits sorted to at least rule tham out, if i can find someone to do the work! Link to post Share on other sites
terrorste 0 Posted April 12, 2010 Author Report Share Posted April 12, 2010 I now need to replace the gear box as the first gear is non existant, i have a new box out of another car but how much should i be looking at paying to get it fitted? Link to post Share on other sites
