bungy 2 Posted December 21, 2009 Report Share Posted December 21, 2009 After lowering my car quite considerably, it threw out the camber front and rear. Although the front is relatively simple, the rear was a little different and there is more than one way of doing it. Here you can see how far out the rear was and looked like it needed wheel spacers to fill the arch.This was my camber before the bushes were fitted. After a little research I chose to use K-mac correction bushes. These were sourced from Sydney, Australia after recommendation from "centre of gravity. The kit came with an extraction tool and were very well made.After some blood, sweat and tears to fit. My rears looked like this and filled the arches nicely. No need now for wheel spacers.The height and camber will settle before final adjustments. Link to post Share on other sites
bungy 2 Posted December 28, 2009 Author Report Share Posted December 28, 2009 After jacking up the car (cheers Jake for lending me the jack ) and removing the wheel, the control arms need removing one at a time to replace the bushes. With a little bit of grease the bushes were fitted and here you can see the eccentric hole that gives you the ability to correct alignment.When bolted up in position which did take some graft and plenty of swearing they'll look like this.The lower arm was adjusted in towards the car and the upper wound outwards away from the car. The initial setup I did with the digital level on my i-phone. Now that both sides were done and checked over i'll leave it overnight to settle before test driving. A couple more days before I make any final adjustments..Here my car tucked in the garage getting ripped apart. Link to post Share on other sites
bungy 2 Posted January 29, 2010 Author Report Share Posted January 29, 2010 This was the rear before correction and i'll take another after once it has settled. Link to post Share on other sites
J5KE F 0 Posted January 29, 2010 Report Share Posted January 29, 2010 Good god u waste no time boy!! Love the detail on his work! I'm gutted I couldn't ge the time off to assist! I owe u big time for all the help u have given me over the past 6 months! No wurries ref the jack! Anytime Link to post Share on other sites
grafteratwork 2 Posted January 29, 2010 Report Share Posted January 29, 2010 nice car matey Link to post Share on other sites
