VR6-RR 0 Posted December 14, 2009 Report Share Posted December 14, 2009 exactly what it says on the tin (well subject)!Earlier today, I tried to let somebody into the passenger door but it is refusing to open from the inside or from outside.Is there anyway of opening the door without cutting the door card?I thought I could open it using the key (owned car for 6 months, only ever used the key to start it!) but all it does is open and close the windows 8-)Any ideas other than paying a fortune to the aa.ThanksRich Link to post Share on other sites
jesterwalker69 0 Posted December 14, 2009 Report Share Posted December 14, 2009 No need to cut the door card fella.If you take out both front seats to give you room to move you can pull the door card free of the door with a little gentle persuasion. It will take a bit of flexing and isn't the easiest of jobs but it can be done. Start at the B pillar and work your way towards the dash. Once you get about half way you can usually flex the card enough to get your hand inside and pop open the door.Don't forget to disconnect speaker and leccy switches first tho, don't want you ripping them off!! Hope you get it sorted Link to post Share on other sites
VR6-RR 0 Posted December 14, 2009 Author Report Share Posted December 14, 2009 thanks mate, I will give that a go later before its get dark. Link to post Share on other sites
dru 0 Posted December 23, 2009 Report Share Posted December 23, 2009 may sound daft but u sure its not frozen?? just that, that is the only door on mine that will not open when its icy Link to post Share on other sites
