The Monk 50 Posted December 10, 2009 Report Share Posted December 10, 2009 I figured I'd give tony a break from the phone calls this time. He's been an angel helping me out with problems.Right, as it stands, my speedo/rev sensor is faulty after I removed it a few days back. Can the sensor being faulty have any efffect on the idle speed or engine revs?I've also been burning my clutch to bits, to the point where after a 12 mile journey of hardly any acceleration, there was smoke coming from the underside of my bellhousing.The engine will rev up to however many revs but you can hear the engine struggling and dipping as the clutch intermitantly and scarcley grips.As far as I'm aware, this means I'll need to remove the gbox yet again. Is there any chance that it is oil/grease on the flywheel or friction plate or an even bigger problem? Link to post Share on other sites
djmorgz 0 Posted December 10, 2009 Report Share Posted December 10, 2009 is there oil inside the bell housing...i had the same as you when i took the g/box off the rear main oil seal was leaking and had covered everything in oil...lol.was easy to do but have to take that damm box off Link to post Share on other sites
The Monk 50 Posted December 10, 2009 Author Report Share Posted December 10, 2009 Thats what I figure has happened. I drove her on 3/4 out of 6 cylinders for 24 miles the other night.....so I could get my better half home off a motorway without spending hours sat in the rain at the edge of it.Given the vibrations, I'm guessing the oil seal might have come apart.There is oil, but coming from the sump near the plug and not from the bell housing as you would expect. Link to post Share on other sites
